Power Options - Add or Remove "Hibernate after"
How to Add or Remove "Hibernate after" in Power Options in Windows
Hibernation is a power-saving state designed primarily for laptops. While sleep puts your work and settings in memory and draws a small amount of power, hibernation puts your open documents and programs on your hard disk, and then turns off your computer. Of all the power-saving states in Windows, hibernation uses the least amount of power. On a laptop, use hibernation when you know that you won't use your laptop for an extended period and won't have an opportunity to charge the battery during that time.
The Hibernate after power option allows users to specify how long in minutes the computer is inactive when on battery or plugged in before automatically hibernating.
This tutorial will show you how to add or remove the "Hibernate after" setting under Sleep in Power Options for all users in Vista, Windows 7, and Windows 8.
EXAMPLE: "Hibernate after" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\238C9FA8-0AAD-41ED-83F4-97BE242C8F20\9d7815a6-7ee4-497e-8888-515a05f02364
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "Hibernate after" from Power Options
Remove_Hibernate_after_Power_Option.reg
3. To Add "Hibernate after" to Power Options
A) If you have not already, you would need to enable hibernate.​
B) Click/tap on the Download button below to download the file below, and go to step 4 below.​
Add_Hibernate_after_Power_Option.reg
