Power Options - Add or Remove "System cooling policy"
    How to Add or Remove "System cooling policy" in Power Options in Windows
    Published by Brink is offline
    30 Jul 2014
    Default Power Options - Add or Remove "System cooling policy"
    Published by
    Brink's Avatar
    The System cooling policy power option allows you to specify the cooling mode you want to use for your system.
    • Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort.
    • Passive = Slow the processor to cool, and only increasing fan speed to cool as a last resort.
    This tutorial will show you how to add or remove the "System cooling policy" setting under Processor power management in Power Options for all users in Vista, Windows 7, and Windows 8.
    EXAMPLE: "System cooling policy" in Power Options
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\94D3A615-A899-4AC5-AE2B-E4D8F634367F
    Attributes DWORD
    1 = Remove
    2 = Add
    2. To Remove "System cooling policy" from Power Options
    Remove_System_cooling_policy.reg
    3. To Add "System cooling policy" to Power Options
    Add_System_cooling_policy.reg
    Microsoft Windows 8.1 64-bit Professional
    Another great tut Shawn
    Nommy
How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows The Minimum processor state is the minimum performance percentage your CPU will automatically decrease to save energy and battery life when there is little CPU demand by the system. You...
How to Add or Remove "When sharing media" in Power Options in Windows The When sharing media setting in Power Options will let users configure power settings for when devices and computers are playing media from your computer to either allow the computer to sleep, prevent idling to sleep, or...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows You can have a slide show (a rotating series of pictures) as your desktop background. You can use your own pictures or pictures that Windows provides as part of a theme. The Slide show power option allows...
How to Add or Remove "Turn off hard disk after" in Power Options in Windows The "Turn off hard disk after" power option setting lets users set to have hard disks power down after a specified time of inactivity is detected. When you set to turn off hard disks after idle, there will be a...
How to Add or Remove "Allow wake timers" in Power Options in Windows The "Allow wake timers" power option setting enables or disables Windows to automatically wake your computer from sleep on a timer for scheduled tasks and other programs. This tutorial will show you how to add or remove...
How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows Away Mode in Windows is similar to Sleep and Hibernate Mode, it turns off the power of most equipment to save energy and can be fast woken up. Away Mode is designed to enable media PC scenarios that include background...
