Published by
Brink's Avatar
How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows
The "Power Saving Mode" option under the Wireless Adapter Settings section is used to configure how much power you want to save when using your wireless network card. There are four types of power saving modes available: Maximum Performance, Low, Medium and Maximum Power Saving. Your wireless network performance goes down with higher power savings. For example, choosing "Maximum Power Saving" will cause your wireless network connection to function at lower speeds.
This tutorial will show you how to add or remove "Power Saving Mode" under Wireless Adapter Settings in Power Options for all users in Vista, Windows 7, and Windows 8.
EXAMPLE: Wireless Adapter Settings "Power Saving Mode" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\19cbb8fa-5279-450e-9fac-8a3d5fedd0c1\12bbebe6-58d6-4636-95bb-3217ef867c1a
Attributes DWORD
1 = Remove
2 = Add
2. Add Wireless Adapter Settings "Power Saving Mode" to Power Options
Add_Power_Saving_Mode_in_Wireless_Adapter_settings.reg
3. Remove Wireless Adapter Settings "Power Saving Mode" from Power Options
Remove_Power_Saving_Mode_in_Wireless_Adapter_settings.reg
