Power Options - Add or Remove "Min/Max processor state"
    How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows
    Published by Brink is online now
    30 Jul 2014
    Default Power Options - Add or Remove "Min/Max processor state"
    Published by
    Brink's Avatar
    The Minimum processor state is the minimum performance percentage your CPU will automatically decrease to save energy and battery life when there is little CPU demand by the system. You would want to keep this percentage the same or lower than the Maximum processor state setting.
    The Maximum processor state is the maximum percentage performance your CPU will automatically increase to save energy and battery life when CPU demand increases. You would want to keep this percentage the same or higher than the Minimum processor state setting.
    This tutorial will show you how to add or remove the "Minimum processor state" and "Maximum processor state" setting under Processor power management in Power Options for all users in Vista, Windows 7, and Windows 8.
    If you enable virtualization in your BIOS or UEFI settings like below, then the Minimum processor state and Maximum processor state power options will not be available, even if you set them to be added.
    Only when virtualization is disabled in BIOS/UEFI will Minimum processor state and Maximum processor state be available in your Power Options.
    EXAMPLE: "Minimum processor state" and "Maximum processor state" in Power Options
    Power Options - Add or Remove "Min/Max processor state" OPTION ONE Power Options - Add or Remove "Min/Max processor state"
    Add or Remove "Minimum processor state" in Power Options
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\893dee8e-2bef-41e0-89c6-b55d0929964c
    Attributes DWORD
    1 = Remove
    2 = Add
    2. To Remove "Minimum processor state" from Power Options
    Remove_Minimum_processor_state.reg
    3. To Add "Minimum processor state" to Power Options
    Add_Minimum_processor_state.reg
    Power Options - Add or Remove "Min/Max processor state" OPTION TWO Power Options - Add or Remove "Min/Max processor state"
    Add or Remove "Maximum processor state" in Power Options
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\bc5038f7-23e0-4960-96da-33abaf5935ec
    Attributes DWORD
    1 = Remove
    2 = Add
    2. To Remove "Maximum processor state" from Power Options
    Remove_Maximum_processor_state.reg
    3. To Add "Maximum processor state" to Power Options
    Add_Maximum_processor_state.reg
    Windows 7
    Is there any way to change the min/max values from the registry or through a batch script or something? When I play games my laptop gets hot, so I switch the max value to 94% just to disable the turbo boost, which in turn lowers my max cpu temp from 100 degrees Celsius to something more acceptable like 70-80, and after I'm done playing I switch back the max cpu power to 100% again. Needless to say this process is very boring, and if I could do all those commands with a double click it'd be awesome.
  3. #2
    Hello Legjendat,
    As a workaround, you could add the context menu in the tutorial below to be able to quickly change power plans on demand. This way you could set two power plans each how you like for the processor state, and use the context menu to toggle between them.
    Power Plan - Choose from Desktop Context Menu in Windows
  4. #3
    Windows 7
    Hmm, that's a very good solution as well so Thank You for the fast response, but while I was googling, I found exactly what I was looking for. A tutorial to change the power through a batch file. If you want, you can add it as part of this or some other tutorial.
    You create a batch file, and add the following commands.
    The commands are simple, and you just change the values at the end of each row.
    powercfg -setacvalueindex SCHEME_CURRENT SUB_PROCESSOR PROCTHROTTLEMIN 5
    powercfg -setdcvalueindex SCHEME_CURRENT SUB_PROCESSOR PROCTHROTTLEMIN 5
    powercfg -setacvalueindex SCHEME_CURRENT SUB_PROCESSOR PROCTHROTTLEMAX 94
    powercfg -setdcvalueindex SCHEME_CURRENT SUB_PROCESSOR PROCTHROTTLEMAX 94
    powercfg.exe -setactive SCHEME_CURRENT
    setacvalueindex is for when the power cord is connected while setdcvalueindex is for when you're not connected to a power plug. I just created two batch files, one for gaming with the stats above and one for full power with max values set at 100, nice and easy
  5. #4
  6. #5
    Windows 7
    Hello Martin, thanks so much for this great info. I'm using the TrekStor Wintron 7.0 Tablet with Windows 10, and these processor state options were missing. I don't know if these were removed intentionally, but nevertheless it has worked. During low demanding tasks the processor liked to be at full clock speed very often. Now it's finally not the case anymore, and as the average battery runtime of this device are 2 hours, this is very helpful.
    And I'm a bit confused about this sentence:
    On my main computer this option is enabled, and processor states are available. During tests with Windows 8.1 and 10, it is the case too. The tablet also supports virtualization, but I don't know if it was missing because of that. It has luckily still worked anyway
    By the way I have to say, I have seen your tips and posts previously many times through my Google searches. And it's always so helpful. Thank you again!
  7. #6
    I'm glad it could help Cloudtime, and welcome to Eight Forums.
  8. #7
    Windows 7 Professional
    Hmm... This did not seem to work for me.
    I downloaded and used the files as instructed, however the options are still not present for me. The strangest part about this is that I incorrectly set them earlier today, and I need to set them back, but now they're gone... I did tinker around in the BIOS in between setting them, but I'm not exactly sure what I hit there that may have affected the settings... I know about the virtualization option having something to do with it, but I've deactivated it so that shouldn't be hiding the options. The only thing I can think is that disabling Intel Speedstep may be the culprit, but I really don't want to have to turn that crap back on, even just to see if that affects the options. What is left that could still be hiding them?
  9. #8
    Hello theataripunk, and welcome to Eight Forums.
    As a test, enable Intel Speedstep in BIOS, and see if the settings are back in Power Options afterwards.
  10. #9
    windows 10
    i have tried all the things above the problem is i cant get my minimum processor state to 5% it set it back to 100% and its eating up my battery how can i set it to 5% i have tried this command powercfg -setdcvalueindex SCHEME_CURRENT SUB_PROCESSOR PROCTHROTTLEMIN 5
    but it is not working the command line says "
    The value specified is malformed, or is not within the range of the target power setting."
    i have enabled and disabled virtualization still it is not working.
Page 1 of 2 12 LastLast
How to Add or Remove "When sharing media" in Power Options in Windows The When sharing media setting in Power Options will let users configure power settings for when devices and computers are playing media from your computer to either allow the computer to sleep, prevent idling to sleep, or...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows You can have a slide show (a rotating series of pictures) as your desktop background. You can use your own pictures or pictures that Windows provides as part of a theme. The Slide show power option allows...
How to Add or Remove "System cooling policy" in Power Options in Windows The System cooling policy power option allows you to specify the cooling mode you want to use for your system. Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort. Passive...
How to Add or Remove "Turn off hard disk after" in Power Options in Windows The "Turn off hard disk after" power option setting lets users set to have hard disks power down after a specified time of inactivity is detected. When you set to turn off hard disks after idle, there will be a...
How to Add or Remove "Allow wake timers" in Power Options in Windows The "Allow wake timers" power option setting enables or disables Windows to automatically wake your computer from sleep on a timer for scheduled tasks and other programs. This tutorial will show you how to add or remove...
How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows Away Mode in Windows is similar to Sleep and Hibernate Mode, it turns off the power of most equipment to save energy and can be fast woken up. Away Mode is designed to enable media PC scenarios that include background...
