Power Options - Add or Remove "Dim display after"
    How to Add or Remove "Dim display after" in Power Options in Windows
    Published by Brink is online now
    26 Nov 2013
    Default Power Options - Add or Remove "Dim display after"
    Published by
    Brink's Avatar
    The display can use more power than any other part of a PC. Reducing the display brightness level can help extend your battery life before needing to recharge.
    The Dim display after setting under Display in Power Options specifies how long your computer is inactive before your display(s) dims.
    This tutorial will show you how to add or remove the Dim display after setting under Display in Power Options for all users in Vista, Windows 7 and Windows 8.
    If you did not originally have the Dim display after option available, then it means that it is not supported on your PC.
    Instead, your display(s) will automatically dim by the percentage set in "Dimmed display brightness" exactly 15 seconds before what is set in "Turn off display after".
    EXAMPLE: "Dim display after" added to Advanced Power Settings
    2. Add "Dim display after" to Advanced Power Settings
    Add_Dim_Display_After.reg
    3. Remove "Dim display after" from Advanced Power Settings
    Remove_Dim_Display_After.reg
    7. You can now delete the downloaded .reg file if you like.
    Oh maaaaaaaaaan ... you are AWESOME, Brink! Thank you so much for the easy tweak!
    I wish you the best of holidays!
  3. #2
    You're most welcome TBolt. I hope you have a great holidays as well.
  4. #3
    {edit}
    No luck thus far. Updated NVIDIA drivers again -- the laptop screen still won't dim.
    Well, this must be a Microsoft or NVIDIA thing that they need to fix. Even though I set the dim to 1 minute in both Balanced Mode & High Performance Mode, the laptop display is not dimming.
    • I disconnected external monitors/TVs.
    • I even turned off the mouse to make sure there was no input to the PC.
    • No videos playing.
    It was a brilliant effort though, Brink!
  5. #4
    Well, so much for that. What I have set for "Dim display after" doesn't get applied for me as well.
    However, I noticed that the display will automatically dim by the percentage set in "Dimmed display brightness" exactly 15 seconds before what is set in "Turn off display after".
  6. #5
    Quote Originally Posted by Brink View Post
    However, I noticed that the display will automatically dim by the percentage set in "Dimmed display brightness" exactly 1 minute before what is set in "Turn off display after".
    Interesting. For me, the main laptop display dimmed 15 seconds before the screen turned off at 2 minutes. Tested it twice - same result.
    So, do you feel this is just a bug that MS will need to fix?
    Thank you, Brink!
  7. #6
    I don't think it's a bug, but was changed for whatever reason. Oops, yep 15 seconds.
  8. #7
    8.1 update
    Hi Brink,
    I just tried your reg fix and yes, it brings the option back up in the advanced settings but it doesn't have any effect.
    My laptop is a HP Compaq 6710b core 2 duo T7500 2.2GHz 3GB RAM now running Win 8.1 update.
    It was working fine in Win 8 but not in the Win 8.1 update.
    I have used the Intel driver update program you suggested in another post and all my drivers are up to date and no problems in the device manager.
  9. #8
    Hello Frog, and welcome to Eight Forums.
    It appears that the Dim display after option is no longer supported on your PC.
  10. #9
    Awesome, thank you Brink. That was one of the many useful features they removed between Win7 and Win8.1. Personally I don't see why they need to make a desktop computer behave like a mobile device. Give it up, Microsoft, a 25-lb tower will never be a tablet no matter how much fat you trim on the software side.
Page 1 of 3 123 LastLast
How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows The Minimum processor state is the minimum performance percentage your CPU will automatically decrease to save energy and battery life when there is little CPU demand by the system. You...
How to Add or Remove "When sharing media" in Power Options in Windows The When sharing media setting in Power Options will let users configure power settings for when devices and computers are playing media from your computer to either allow the computer to sleep, prevent idling to sleep, or...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows You can have a slide show (a rotating series of pictures) as your desktop background. You can use your own pictures or pictures that Windows provides as part of a theme. The Slide show power option allows...
How to Add or Remove "System cooling policy" in Power Options in Windows The System cooling policy power option allows you to specify the cooling mode you want to use for your system. Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort. Passive...
How to Add or Remove "Turn off hard disk after" in Power Options in Windows The "Turn off hard disk after" power option setting lets users set to have hard disks power down after a specified time of inactivity is detected. When you set to turn off hard disks after idle, there will be a...
How to Add or Remove "Console lock display off timeout" in Power Options in Windows 8 and 8.1 Console lock display off timeout is the amount of minutes Windows will wait idle with no activity while on the lock screen before timing out and automatically turning off the display. This...
