Power Options - Add or Remove Link State Power Management
How to Add or Remove PCIe "Link State Power Management" in Power Options in Windows
The Link State Power Management is a part of PCI Express Active State Power Management (ASPM). The link State of a PCIe Device is converted from L0 (on) to L1 (off) when the link is not transferring data. The hardware is automatically converted to L0 again when data is available to transfer across the link.
This tutorial will show you how to add or remove the "Link State Power Management" setting under PCI Express in Power Options for all users in Vista, Windows 7, and Windows 8.
EXAMPLE: "Link State Power Management" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\501a4d13-42af-4429-9fd1-a8218c268e20\ee12f906-d277-404b-b6da-e5fa1a576df5
Attributes DWORD
1 = Remove
2 = Add
2. To Remove PCIe "Link State Power Management" from Power Options
Remove_PCI_Express_Link_State_Power_Mangement.reg
3. To Add PCIe "Link State Power Management" to Power Options
Add_PCI_Express_Link_State_Power_Mangement.reg
  • Add_PCI_Express_Link_State_Power_Mangement.reg
  • Remove_PCI_Express_Link_State_Power_Mangement.reg
