Solved Audio service not running
Please find attached the screenshot of device manager and also msinfo.
  • Msinfo32.zip
    Windows 8 Consumer Preview
I have to be honest with ya - the machine is quite messy, software wise. There are tons of things starting with Windows that should not be.
RealPlayer is spyware so I very much recommend to uninstall that. I also would use Task Manager or Regedit to disable or delete all the unnecessary programs starting with Windows.
As for the actual DVD drive problem - if you're already sure you deleted the upper/lower filters as shown or they didn't exist to begin with...
then Microsoft does list Zune as a problem software in relation to this:
"If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
  • iTunes software by Apple
  • Nero software by Nero Inc
  • Roxio Creator software by Sonic Solutions
  • Zune software by Microsoft"
So I would uninstall that then reboot. If the drive still is not shown, check upper/lower filters again and/or reinstall newest version of Zune.
Good luck.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I removed real player, tried reinstalling Zune. But still no DVD drive pops up when a cd or dvd is put in the drive. I am not able to copy anything from a cd to my pc n vice versa :(
Well, you had no DVD for a while now. Unless there is some urgent need, your best course of action would probably be to wait 2-3 weeks until the Release Preview of 8 is made available to the public from Microsoft, because you'll probably want that anyway. Right?
So then just clean install that when it arrives instead of clean installing the CP now.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
The DVD drive may be failing - as electromechanical devices, optical drives can develop internal short- or open-circuits due to fracture or tension failure of conductors on flat ribbon conductors. Fortunately the drives are now inexpensive and easy to replace.
A failing DVD drive can cause odd behaviour like slow bootup and slow Explorer windows, and other difficult-to-trace problems. Disconnecting the drive may make the system behave normally again. If this is so for you, then the course of action is clear, and a new drive may solve your problem..
    HP COMPAQ Presario CQ57
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
    Chrome Canary usually
    no Start menu modifications
But it shows in the bios! heh heh
It's gotta be a software issue, especially since it was an upgrade with all sorts of troublesome software on it when it was upgraded.
(Zune, Norton and others.)
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
It doesn't matter it shows in the bios - if the hardware fails to find any media due to the fault, there is no drive available, windows tries to find the removable media (optical) and fails - It has happened on a laptop of mine, (drive ribbon crimped and shorting against DVD aluminium casing) and when the drive was removed physically, everything went back to normal. Replaced DVD-writer and all was OK.DSCF10051.JPG
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
That is not true. A DVD drive which shows in the bios well, regardless if there is media inserted or not, will automatically be enumerated by Windows and available in the Device Manager, unless there is a software issue preventing that.
Windows can not even begin to attempt to find if there is media present or not, if the drive is not in the Device Manager, so the theory is incorrect.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
Windows may hide removable drives when no media is present, including dvd. Windows 7 does it by default.
Does it appear as a hidden device in devmgmt.msc?
There's also a Fix it if it is software installation (registry??) related
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
Windows 7 doesn't do it by default.
No, nothing can cause an optical drive to be hidden in the Device Manager when it is otherwise functional.
We have addressed the upper/lower filters many times already in this thread.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I answered this one already ages ago.
It is under HKLM\CCS\SERVICES\AUDIOSRV
#9
    7/8/ubuntu/Linux Deepin
In addition to the boot screen, I have attached a picture of the diagnostics for your viewing.
And also i noted down in case the picture doesnt seem clear, wat appeared in the diagnostic screen:
Testing : WDC WD 3200AAJS-65M0A0 (WD-WMAV24021591) Drive
Error code : BIOHD-8
Error : A SMART test failed on the drive.
Suggestion : Back up your important data.
Suggestion : Please contact HP support.
Any suggestion/s regarding this?
Replace the HDD.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Yuuuup.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
But it was working fine when i was using windows xp. Wouldnt it be due upgrade installation to windows 8 CP?
No. SMART works at hardware level. It doesn't matter what you put on or installed on the drive. You need to get anything off it that you don't want to lose immediately, then replace it.
Old drives fail very often and since yours is from XP days, it is surely failing as SMART told you.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Will it work under Windows 7 then? Once the consumer preview expires, i might not go for purchasing the final windows 8. So i will have to revert to Windows 7.
