Audio Service not running
    United States
    Windows 8 developer preview
    My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to troubleshoot this?
    Bay Area
    Windows 7 Home Premium x64
    Start> In search window type services.msc> Enter> Scroll down to Windows Audio> Right click on Windows Audio> Click on dependency tab> Make sure the dependencies are also started (often it is Multimedia Class Scheduler that is not started).
    A Guy
    United States
    One of the errors on windows audio service is 1297 a privilege that the service requires to function properly does not exist in the service account configuration. It goes on with something about MMC and secpol.msc. Multi Class was not running but I was able to start that.
    Bay Area
    United States
    Anything here that may help? I have not used registry editor in years.
    United States
    I still have been unable to resolve my sound issue, would replacing my sound card with something more recent than the Creative 2Z S help. I'm not even sure if this is a hardware or software issue or a combination of both.
    I'd recommend you wait for the Beta and try again.
    Then you'll have a better idea if you should scrap your old card and spend the money on a new one.
    That being said, however, if money is no issue ... well ...
    In the meantime, if you want sound, looks like you should stick with Win7.
    United States
    I'm not sure that 7 would work as I went from XP to 8, I can go back to XP or go out and purchase 7 that would cost more than a sound card.
    7/8/ubuntu/Linux Deepin
    Where it says RequiredPrivileges in your screenie - delete them all except the first one.
    Ah, missed that one, SIW2. Nice.
Page 1 of 2 12 LastLast
As you can see I am having the problem of audio service not running. I have read a couple threads and tried to do the recovery but my control panel just freezes up. Please help with any further options. Thanks
on my HP all-in-one computer, windows 8.1 was auto installed - the sound worked fine for a day, now it doesnt - also, i cant access the control panel - how can i fix this, and where can i get a free update or audio device?
Hello, fellow... meh, I don't know. OS: Windows 8.1 Pro Processor: AMD FX-1400 Quad Core RAM: 8.00 GB Storage: 1.73 TB of 1.81 TB available System Type: 64-bit Operating System, x64 based processor ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ A...
My issue started a day or two ago when I installed a windows update. I go to watch something the next day, and no sound is coming from the computer. I double check the connections, update the drivers and still get nothing. I look around online and most people who have had similar issues had...
Solved Audio service not running in Sound & Audio
Hello, i installed windows 8 CP a few days back and i have been facing quite a few problems. The main one being the audio service not working. I tried a lot of solutions that have been given on the internet but its to no avail. When i try to start the windows audio service from the services screen,...
