Power Options - Add or Remove "Min/Max processor state"
How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows
The Minimum processor state is the minimum performance percentage your CPU will automatically decrease to save energy and battery life when there is little CPU demand by the system. You would want to keep this percentage the same or lower than the Maximum processor state setting.
The Maximum processor state is the maximum percentage performance your CPU will automatically increase to save energy and battery life when CPU demand increases. You would want to keep this percentage the same or higher than the Minimum processor state setting.
This tutorial will show you how to add or remove the "Minimum processor state" and "Maximum processor state" setting under Processor power management in Power Options for all users in Vista, Windows 7, and Windows 8.
If you enable virtualization in your BIOS or UEFI settings like below, then the Minimum processor state and Maximum processor state power options will not be available, even if you set them to be added.
Only when virtualization is disabled in BIOS/UEFI will Minimum processor state and Maximum processor state be available in your Power Options.
EXAMPLE: "Minimum processor state" and "Maximum processor state" in Power Options
Add or Remove "Minimum processor state" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\893dee8e-2bef-41e0-89c6-b55d0929964c
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "Minimum processor state" from Power Options
Remove_Minimum_processor_state.reg
3. To Add "Minimum processor state" to Power Options
Add_Minimum_processor_state.reg
Add or Remove "Maximum processor state" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\bc5038f7-23e0-4960-96da-33abaf5935ec
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "Maximum processor state" from Power Options
Remove_Maximum_processor_state.reg
3. To Add "Maximum processor state" to Power Options
Add_Maximum_processor_state.reg
  • Add_Maximum_processor_state.reg
  • Add_Minimum_processor_state.reg
  • Remove_Maximum_processor_state.reg
  • Remove_Minimum_processor_state.reg
Hi Shawn. I created an account just to say THANK YOU for this tutorial. I was going crazy not being able to set minimum power to 100% when charging. It was reset to 5% by some idiot OS upgrade which also wiped my High Performance plan.
THANK YOU.
    Windows 10
I'm glad it could help florini, and welcome to Eight Forums. :)
