Power Options - Add or Remove "Slide Show"
How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows
You can have a slide show (a rotating series of pictures) as your desktop background. You can use your own pictures or pictures that Windows provides as part of a theme.
The Slide show power option allows users to specify when they want the desktop background slide show to be available or paused when on battery or plugged in.
This tutorial will show you how to add or remove the "Slide show" setting under Desktop background settings in Power Options for all users in Windows 7 and Windows 8.
EXAMPLE: "Slide show" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\0d7dbae2-4294-402a-ba8e-26777e8488cd\309dce9b-bef4-4119-9921-a851fb12f0f4
Attributes DWORD
1 = Remove
2 = Add
2. To Remove Desktop Background "Slide Show" from Power Options
Remove_Desktop_Background_Slide_Show_Power_Option.reg
3. To Add Desktop Background "Slide Show" to Power Options
Add_Desktop_Background_Slide_Show_Power_Option.reg
  • Add_Desktop_Background_Slide_Show_Power_Option.reg
  • Remove_Desktop_Background_Slide_Show_Power_Option.reg
