Start Screen - Allow or Prevent Users from Customizing
How to Allow or Prevent Users from Customizing Start Screen in Windows 8 and 8.1
The Start screen is a new feature in Windows 8 and Windows RT that replaces the Start Menu from previous Windows. You can pin Store apps, programs, folders, drives, files, contacts, and websites to Start to quickly access what you use most. All of your apps—both apps you install from the Windows Store and desktop apps—are available from the Start screen. You can organize, group, and name categories of apps to how you like on the Start screen. Tiles and notifications show what’s new so you can get important info and updates at a glance.
The Apps screen in Windows 8 and Windows 8.1 is the new version of the Start Menu -> All Programs that was in Windows 7 and Vista. The Apps screen displays all of your installed Store apps and desktop programs.
In Windows 8.1 and Windows RT 8.1, the Start screen can be viewed in either Start or Apps view.
This tutorial will show you how to allow or prevent all or specific users from being able to customize their Start screen in Windows 8, Windows RT, Windows 8.1, or Windows RT 8.1.
Affected Start screen customizations:
  • Drag and drop tiles to arrange apps on Start screen.
  • Name or rename groups of apps on Start screen.
  • Resize app tiles on Start screen.
  • The ability to "Pin to Start" anything from anywhere.
  • "Unpin from Start" by selecting (press and hold or right click) an app in Start and Apps view.
  • "Pin to taskbar" or "Unpin from taskbar" by selecting (press and hold or right click) a desktop app in Start and Apps view. You will still be able to "Pin/unpin to/from taskbar" desktop apps from File Explorer.
  • "Uninstall" app by selecting (press and hold or right click) an app in Start and Apps view. You will still be able to uninstall desktop apps in Programs and Features.
  • "Turn live tile on/off" by selecting (press and hold or right click) an app in Start and Apps view.
Enable or Disable Users from Customizing Start Screen using a REG File
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoChangeStartMenu DWORD
0 = Allow All Users to Customize their Start Screen
1 = Prevent All Users to Customize their Start Screen
2. To Allow Current User to Customize their Start Screen
Allow_Users_to__Change_Start_Screen.reg
3. To Prevent Only Current User to Customize their Start Screen
Prevent_Users_to_Change_Start_Screen.reg
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve.​
7. Restart explorer, sign out and sign in, or restart the PC to apply.​
Enable or Disable Control Panel and PC settings in Group Policy
NOTE: This option for using group policy is only available in the Windows 8/8.1 Pro and Windows 8/8.1 Enterprise editions.
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.​
2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Start Menu and Taskbar. (see screenshots below step 3 or 4)​
3. In Windows 8 and Windows RT, double click/tap on Remove drag-and-drop and context menus on the Start Menu in the right pane of Start Menu and Taskbar, and go to step 5 below. (see screenshot below)​
4. In Windows 8.1 and Windows RT 8.1, double click/tap on Prevent users from customizing their Start Screen in the right pane of Start Menu and Taskbar, and go to step 5 below. (see screenshot below)​
6. To Enable Access to Control Panel and PC settings
A) Select (dot) Disabled or Not Configured, click/tap on OK, and go to step 8 below. (see screenshots below step 7A)​
7. To Disable Access to Control Panel and PC settings
A) Select (dot) Enabled, click/tap on OK, and go to step 8 below. (see screenshots below)​
8. You can now close the Local Group Policy Editor window if you like.​
  • Allow_Users_to__Change_Start_Screen.reg
  • Prevent_Users_to_Change_Start_Screen.reg
