Audio service not running
  1. #51
    India
    Windows 8 Consumer Preview
    So i guess i will wait till the release preview comes out.
  2. #52
    7/8/ubuntu/Linux Deepin
    I answered this one already ages ago.
    It is under HKLM\CCS\SERVICES\AUDIOSRV
    #9
  3. #53
    India
    SIW2, the audio problem was solved. My other query-DVD drive not showing, thats yet to be.
  4. #54
    India
    In addition to the boot screen, I have attached a picture of the diagnostics for your viewing.
    And also i noted down in case the picture doesnt seem clear, wat appeared in the diagnostic screen:
    Testing : WDC WD 3200AAJS-65M0A0 (WD-WMAV24021591) Drive
    Error code : BIOHD-8
    Error : A SMART test failed on the drive.
    Suggestion : Back up your important data.
    Suggestion : Please contact HP support.
    Any suggestion/s regarding this?
  5. #55
    Replace the HDD.
  6. #56
    India
    GMan, by replace do you mean i need to get a new hard drive?
  7. #57
    Yuuuup.
  8. #58
    India
    But it was working fine when i was using windows xp. Wouldnt it be due upgrade installation to windows 8 CP?
  9. #59
    Quote Originally Posted by aswinbarathb View Post
    No. SMART works at hardware level. It doesn't matter what you put on or installed on the drive. You need to get anything off it that you don't want to lose immediately, then replace it.
    Old drives fail very often and since yours is from XP days, it is surely failing as SMART told you.
  10. #60
    India
    Will it work under Windows 7 then? Once the consumer preview expires, i might not go for purchasing the final windows 8. So i will have to revert to Windows 7.
Page 6 of 7 FirstFirst ... 4567 LastLast
As you can see I am having the problem of audio service not running. I have read a couple threads and tried to do the recovery but my control panel just freezes up. Please help with any further options. Thanks
on my HP all-in-one computer, windows 8.1 was auto installed - the sound worked fine for a day, now it doesnt - also, i cant access the control panel - how can i fix this, and where can i get a free update or audio device?
Hello, fellow... meh, I don't know. OS: Windows 8.1 Pro Processor: AMD FX-1400 Quad Core RAM: 8.00 GB Storage: 1.73 TB of 1.81 TB available System Type: 64-bit Operating System, x64 based processor ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ A...
My issue started a day or two ago when I installed a windows update. I go to watch something the next day, and no sound is coming from the computer. I double check the connections, update the drivers and still get nothing. I look around online and most people who have had similar issues had...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
