Audio service not running
  1. #31
    India
    Windows 8 Consumer Preview
    I removed the antivirus in safe mode. I installed the chipset from this link http://downloadcenter.intel.com/Deta...&DownloadType=
    I tried putting in a DVD to see if it pops up then. I still dont find my DVD drive.
  2. #32
    I would make sure that C:\Windows\System32\drivers\n360 folder has been deleted. If not, delete it then reboot.
    The same for: C:\program files\common files\symantec shared\
    Other than that, I'm out of ideas unfortunately. I looked over everything again and there is nothing new to say.
    Two things I would do if it were mine would be to install the drive in another machine and install newest flash update to it. Install latest bios update for the motherboard as well. And if that doesn't fix it, then clean install Windows from scratch, instead of the upgrade.
    Best of luck.
  3. #33
    I found this to try:
    1. Run Command Prompt as an Administrator. Type cmd in Windows 8 Metro UI and press cltr+shift+enter
    2. Type following and say enter
    reg.exe add "HKLM\System\CurrentControlSet\Services\atapi\Controller0" /f /v EnumDevice1 /t REG_DWORD /d 0x00000001
    3. Reboot the system
    4. Verify if the problem has been resolved.
  4. #34
    India
    Ran the above function. It said operation completed successfully and i restarted the pc. No drive yet.
    Can it be mapped?
  5. #35
    India
    Hello Gman. Will the DVD drive appear if i reinstall windows 8 CP again?
  6. #36
    Is the drive shown in the bios settings or is it missing?
  7. #37
    India
    Its missing..
  8. #38
    Then no, reinstalling Windows would be pointless. I'd check the data cable to motherboard and/or replace it.
    Also make sure the power connector is inserted well. You can tell if power is the issue or not by simply pressing the eject button and seeing if it reacts or not.
    Set Optimized Defaults in the bios, too, then save. Manually enable the drive in the bios settings if needed, then save.
  9. #39
    India
    The data cable is inside or outside the CPU? And the dvd drive opens wen i press the eject button.
    And also in the boot screen this was shown:
    The DVD drive is listed as Atapi DVD A DH16A in the bios screen. When i clicked on enter, it showed:
    Smart Support : Not supported
    Capacity : 0MB
    Transfer Mode : UDMA5
    Does this mean the drive is listed?
  10. #40
    Yes, all is well physically and power-wise. No need to worry about anything like that any more.
    You can take a screenshot of the Device Manager in Windows 8 and attach here.
    Also, type msinfo32 in the start menu then press Enter. File | save on the opened screen. Right click the saved file and choose Send To>>>Compressed (Zip) folder. Then also attach the zip made to here.
Page 4 of 7 FirstFirst ... 23456 ... LastLast
As you can see I am having the problem of audio service not running. I have read a couple threads and tried to do the recovery but my control panel just freezes up. Please help with any further options. Thanks
on my HP all-in-one computer, windows 8.1 was auto installed - the sound worked fine for a day, now it doesnt - also, i cant access the control panel - how can i fix this, and where can i get a free update or audio device?
Hello, fellow... meh, I don't know. OS: Windows 8.1 Pro Processor: AMD FX-1400 Quad Core RAM: 8.00 GB Storage: 1.73 TB of 1.81 TB available System Type: 64-bit Operating System, x64 based processor ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ A...
My issue started a day or two ago when I installed a windows update. I go to watch something the next day, and no sound is coming from the computer. I double check the connections, update the drivers and still get nothing. I look around online and most people who have had similar issues had...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
