Surface Pro 3 September 15th 2015 updates
The following updates will be listed as “System Firmware Update – 9/15/2015” or “System Hardware Update – 9/15/2015” when you view your update history.
:note: Note
When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
• USB 3.0 Card Reader driver update (v10.0.10240.31217) improves the system power usage when an SD card is inserted.
:note: Note
- 64-bit Windows 10
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Custom self built
- CPU
- Motherboard
- Memory
- 64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
- Graphics Card(s)
- Sound Card
- Monitor(s) Displays
- 2 x Samsung Odyssey G7 27"
- Screen Resolution
- 2560x1440
- Hard Drives
- 1TB Samsung 990 PRO M.2,
- PSU
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Keyboard
- Logitech wireless K800
- Mouse
- Logitech MX Master 3
- Internet Speed
- Browser
- Internet Explorer 11
- Antivirus
- Other Info
- Logitech Z625 speaker system,
