Surface Pro 3, Pro 2, and Pro Firmware and Driver Packs
Surface Pro 3, Pro 2, and Pro Firmware and Driver Packs Download
Tip   Tip
All Surface firmware updates are released through Windows Update by default.
Download Surface Pro 3, Pro 2, and Pro Firmware and Driver Packs
Date Published: May 21st 2015
Surface RT update history
Surface 2 update history
Surface 3 update history
Surface Pro update history
Surface Pro 2 update history
Surface Pro 3 update history
There are multiple files available for this download.Once you click on the "Download" button, you will be prompted to select the files you need.
I just downloaded the firmware, but I'm hesitant to install it, my surface pro is working without any problems, I'll wait for now.
    Win 8.1 pro / win 8.1
    Surface Pro 2/ HP Desktop
    core i5 \ AMD E1 - 1200 APU
    4gb \ 4gb
    128gb ssd
April 2014 updates
No product updates were released for Surface RT, 2, Pro, and Pro 2 in April.
Surface Pro, RT June 2014 updates
  • No product updates were released for Surface Pro in June.
Surface Pro 2 June 2014 updates
The following updates will be listed as “System Firmware Update – 6/10/2014” when you view your update history.
  • Surface Pro UEFI (v2.4.950.0) and Surface Pro Embedded Controller Firmware (v24.1.50.0) updates enhance system stability with microSD products, improves compatibility with Power Cover, and increases the reliability of sleep state transitions. Surface Pro UEFI update also provides support for PXE boot with the new Surface Ethernet Adapter.
  • Surface Pro System Aggregator Firmware (v2.4.350.0) update improves sleep state transitions when a Surface Cover is attached.
  • Surface Accessory Device (v2.0.287.0) update improves sleep state transitions when a Surface Cover is attached.
  • Surface Power Cover Firmware Update (v2.0.288.0) improves reliability when the Power Cover is attached to Surface and folded behind Surface.
  • HD Graphics Family (v10.18.10.3496) update improves Miracast wireless display experience and enhances display stability.
Surface 2 June 2014 updates
  • Surface 2 UEFI (v4.21.500.0) update enhances overall system stability, including boot and reboot scenarios, compatibility with Surface Power Cover, and increased battery life when Surface 2 is not in use.
  • System Aggregator Firmware (v1.0.50500.0) update enhances the charging behavior of the Power Cover.
  • Surface Power Cover Firmware Update (v2.0.595.0) update improves battery life when using the Power Cover with Surface 2.
  • Surface Platform Power Driver (v2.0.557.0) update improves battery life when used with the Surface Power Cover.
  • Audio Driver Set (v 9.17.13.2819) and Display Driver Set (v 9.17.13.2818). This update provides enhanced support for external displays, improves the Miracast experience, and enhances the overall system stability while reducing power consumption in many scenarios.
  • Surface Accessory Device (v2.0.583.0) update enhances the experience when using a Surface Cover.
In addition to the updates listed above, an additional update for Surface 2 4G LTE is listed below:
  • Wireless Network Controller (v14.62.28061.10179) and Bluetooth (v14.62.28061.10179) update simplifies and improves tethering for Surface 2 4G LTE.
Surface RT July 2014 updates
The following updates will be listed as “System Hardware Update – 7/8/2014” within the Windows Update History.
:note: Note
When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update, please manually check Windows Update later.
  • Surface Home Button Driver (v1.0.255.0) enhances system stability in both the active state and the sleep/wake transition state.
Surface Pro July 2014 updates
The following updates will be listed as “System Firmware Update – 7/8/2014” within the Windows Update History.
:note: Note
  • Surface Pro System Aggregator Firmware (v2.84.0350) improves battery management when a Surface Cover is attached.
  • Surface Pro UEFI (v1.6.350) provides support for PXE boot with the new Surface Ethernet Adapter.
  • Intel(R) HD Graphics 4000 (v10.18.10.3496) improves Miracast wireless display experience and enhances display stability.
  • Intel(R) Display Audio (v6.16.00.3135) enhances compatibility and improves the display experience for DisplayPort monitors.
  • Surface Accessory Device (v1.0.338.0) improves the experience when using Surface accessories.
  • Surface Power Cover Firmware update (v1.0.339.0) improves the experience when using Surface Power Cover.
Surface Pro 2 July 2014 updates
:note: Note
  • Wireless Network Controller (v 14.69.24054.176) enables functionality on wireless networks utilizing hidden SSIDs.
Surface Pro 3 July 2014 updates
:note: Note
  • Surface Pro Embedded Controller Firmware (v.38.2.50.0) reducing power consumption, and enhancing system stability.
  • Surface Pro System Aggregator Firmware (v. 3.8.250.0) enhancing battery life, and increasing efficiency and reliability in low power states.
  • Surface Type Cover Firmware Update (v. 2.0.1021.0) improving trackpad reliability and system stability.
  • Surface Accessory Device (v. 2.0.1012.0) helping the on-screen keyboard (OSK) appear and disappear at the correct times.
  • Wireless Network Controller and Bluetooth (v. 15.68.3042.79) enhancing system stability, reducing power consumption in low power states, and improving some WiFi connection scenarios. Look for another WiFi update coming soon.
  • We will also issue an update on Wednesday, July 16, to further improve Wi-Fi connection and throughput scenarios.
Hi Brink
Thanks for the Surface Pro 3 update --currently my device seems to be working fine no probs with OSK for the keyboard etc so far-- I'm a bit of an old fashioned engineer in these cases --"If it ain't broke - don't fix it".
The device performs far better than I ever expected -- Ms should have a real winner for this one even though by a lot of people's standards the device is not cheap.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
Surface Pro 3 July 16 release
The following updates will be listed as “System Firmware Update – 7/16/2014” or “System Hardware Update – 7/16/2014” when you view your update history.
:note:Note
When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
  • Surface Integration (v.2.0.1038.0) further enhances system stability.
  • Wireless Network Controller and Bluetooth (v. 15.68.3044.85) further improving WiFi connection and throughput scenarios.
Surface 2 July 22 release
The following updates will be listed as “System Firmware Update – 7/22/2014” or “System Hardware Update – 7/22/2014” when you view your update history.
:note:Note
This update is only available for Surface 2 4G LTE:
  • Modem Firmware Update (v. 5.706.306.2) improves the reliability of the Surface 2 4G LTE on the AT&T 4G LTE network.
Surface Pro August 2014 updates
The following updates will be listed as “System Firmware Update – 8/12/2014” or “System Hardware Update – 8/12/2014” when you view your update history.
:note:Note
  • Wireless Network Controller and Bluetooth (v14.69.24054.176) improves network connection stability and enables functionality on WiFi networks using a hidden SSID.
Surface RT August 2014 updates
The following updates will be listed as “System Firmware Update – 8/12/2014” when you view your update history.
:note:Note
  • Surface RT UEFI (v3.31.500) enhances overall system stability.
Surface Pro 3 August 2014 updates
:note:Note
  • Surface Pro UEFI (v3.9.150.0) adds features to display BIOS password state and asset tag information, as well as improving boot times in some scenarios
  • Surface Pro Embedded Controller Firmware (v38.4.50.0) improved support for Surface Power Cover.
  • Surface Pro System Aggregator Firmware (v3.9.250.0) improved support for Surface Power Cover and enhances overall system stability.
  • Microsoft LifeCam Front (v5.20.1034.0) significantly improves power consumption during video chat such as Skype, supports Flash camera streaming in Internet Explorer, and improves overall functionality and stability.
  • Surface Ethernet Adapter (v8.14.0704.2014) improved support for the gigabit Surface Ethernet Adapter.
Surface Pro 3 September 2014 updates
The following updates will be listed as “System Firmware Update – 9/9/2014” when you view your update history.
:note: Note
  • Surface Pro UEFI update (v3.10.250.0) improves system experience and enhances overall system stability, including Wi-Fi.
  • Surface Pro Embedded Controller Firmware update (v38.6.50.0) enhanced support for system performance and user experience, including thermostat icon on boot.
  • Surface Pro System Aggregator Firmware update (v3.9.350.0) increases the overall system reliability and compatibility with a Surface cover.
  • Surface Integration driver update (v2.0.1102.0) enhances user experience, including Wi-Fi stability.
  • Surface Wi-Fi and Bluetooth driver update (v15.68.3055.107) improves Wi-Fi/ Bluetooth reliability and system stability, and significantly enhances the user experience.
Surface Pro 3 October 28th 2014 updates
The following updates will be listed as “System Firmware Update – 10/28/2014” when you view your update history.
:note: Note
•Surface Pro UEFI update (v3.11.250.0) enhances the system stability, increases the reliability of the graphics display performance, and adds a status bar to the experience when applying future System Firmware Updates.
•Surface Pro Embedded Controller Firmware update (v38.7.50.0) increases the reliability of sleep state transitions with a Surface Pro 3 Docking Station connected.
•Surface Integration update (v2.0.1168.0) addresses setting the Hibernate value in Windows 10.
•Intel(R) 8 Series PCI Express Root Port #3 - 9C14 update (v2.0.1151.0) addresses cases when the Wi-Fi adapter is not available upon resuming the system from sleep.
•Wireless Network Controller and Bluetooth driver update (v15.68.3059.117) improves Wi-Fi throughput, especially after rebooting with Bluetooth devices that are paired, enhances power consumption situations, and addresses instances of system instability.​
Surface Pro 3 November 18th 2014 updates
The following updates will be listed as “System Firmware Update – 11/18/2014” within the Windows Update History
:note: Note
  • Surface Pro UEFI update (v3.11.350.0) enhances the system stability, optimizes the boot time with fast boot enabled, and resolves date and time accuracy when the battery level falls below 3%. Also addresses compatibility with McAfee Defense Encryption 7.1.1.
  • Surface Home Button driver update (v2.0.1174.0) enables future functionality for the Surface Hub app.
  • Surface Pen Settings driver update (v2.5.14.0) enables future functionality for the Surface Hub app.
  • Wireless Network Controller and Bluetooth driver update (v15.68.3066.135) enhances Wi-Fi throughput, especially after waking up from Connected Standby, reduces instances of system instability, increases the connectivity performance and also addresses connectivity while using 5ghz DFS channel.
Surface Pro January 2015 updates
Note
  • Surface Pro UEFI update (v1.7.50) further enhances the system security.
Surface Pro 2 January 2015 updates
Note
  • Wireless Network Controller (v14.69.24054.176) enables functionality on wireless networks utilizing hidden SSIDs.
Surface Pro 3 January 2015 updates
Note
  • Surface Pro UEFI update (v3.11.450.0) adds support for updated HD Graphics Family driver.
  • HD Graphics Family driver update (v10.18.14.4029) enhances display stability and performance, improves user experience when using Miracast adapters. Improves compatibility with DisplayPort monitors and daisy chaining.
  • Wireless Network Controller and Bluetooth driver update (v15.68.3073.151) addresses connectivity issues while Hyper-V is enabled. Adds an advanced feature to control the 2.4Ghz and 5Ghz band preference.
  • Surface Home Button driver update (v2.0.1179.0) ensures compatibility with the Surface Hub app.
  • Microsoft Docking Station Audio Device driver update (v1.31.35.7) improves the user experience while using the Surface Pro 3 Docking Station so that sound is available when a speaker is not connected to the docking station.
Surface Pro 3 March 26th 2015 updates
The following updates will be listed as “System Firmware Update – 3/26/2015” when you view your update history.
Note
  • Surface Pro UEFI (v3.11.760.0) adds support for enterprise disk encryption, enhances the advanced configuration settings for device security, and adds configurable support from the Windows OS for provisioning scenarios.
Surface Pro 3 March 10th 2015 updates
The following updates will be listed as “System Firmware Update – 3/10/2015” or “System Hardware Update – 3/10/2015” when you view your update history.
Note
  • Surface Pen Settings driver update (v3.0.64.0) enables new functionality and features for the Surface app found in the Windows Store.
I just got a firmware update for my surface pro 3, wonder if it is in for preperstion for 10
    4 Windows 7 Pro Sp1- 4 Win 8 Pro, 1- xp pro sp3
    Dell Optiplex 390, 380, 3 Vostro Laptops (7 computers in all)
    desktop/laptop
    4gigs
    atm randioum
Surface Pro 3 April 30th 2015 updates
Note
  • Surface Type Cover Filter Device update (v2.0.1193.0) enables full support for Japanese Surface Pro Type Covers.
  • Surface Pen Settings driver update (v4.0.112.1) enables new functionality with the Surface app, available for free in the Windows Store.
Surface Pro 2 May 2015 updates
The following updates will be listed as “System Firmware Update – 5/19/2015” within the Windows Update History
:note: Note
  • Surface Pro UEFI update (v2.5.250.0) includes changes needed for compatibility with the updated graphics driver.
  • HD Graphics Family driver update (v10.18.14.4170) improves graphic performance and includes better Miracast (wireless display) support.
  • Display Audio driver update (v6.16.00.3172) improves audio experience and supports compatibility with the updated graphics driver.
Surface Pro 3 May 2015 updates
:note: Note
  • •Surface Pro 3 UEFI update (v3.11.850.0) includes changes needed for compatibility with the updated graphics driver.
  • •HD Graphics Family driver update (v10.18.14.4170) improves graphics performance and includes better Miracast (wireless display) support.
  • •Display Audio driver update (v6.16.00.3172) improves audio experience and supports compatibility with the updated graphics driver.
Surface 3 June 23rd 2015 updates
The following updates will be listed as “System Firmware Update – 6/23/2015” when you view your update history.
:note: Note
  • Surface System Aggregator Firmware update (v1.0.49500.0) improves the experience while using the Surface Cover.
  • Audio Device driver update (v603.9600.2563.61816) enhances audio performance and improves the audio experience on Surface 3.
  • Camera driver update (v20.9600.3444.120) enhances the image and video quality while using camera.
  • HD Graphics driver update (v10.18.14.4175) improves the display stability and graphics performance.
  • Wireless Network Controller and Bluetooth driver update (v15.68.3091.193) improves the system stability and the Wi-Fi connectivity experience, also increases the network download performance.
Surface Pro 3 June 23rd 2015 updates
:note: Note
  • Surface Pro UEFI update (v3.11.950.0) adds support for new features in Windows 10.
  • SATA AHCI Controller driver update (v9.4.0.1028) stabilizes deployment methodology on Surface Pro 3.
The following updates will be listed as “System Firmware Update – 7/23/2015” when you view your update history.
:note: Note
This update is available only for Surface 3 (4G LTE):
  • Surface UEFI update (v1.50410.218.0) improves mobile broadband network connectivity.
  • USB 3.0 Host Controller Adaptation driver update (v603.9600.2588.2097) improves mobile broadband network connectivity.
  • USB Composite Device driver update (v2.0.268.0) improves mobile broadband network connectivity.
  • Surface_IA7260.inf update driver for delivering future updates and refreshing production software signing.
  • Surface CoSAR driver update (v2.0.270.0) improves mobile broadband network connectivity.
Surface Pro 3 July 23rd 2015 updates
:note: Note
No product updates were released for Surface Pro 3 running Windows 8.1 in July.
Windows 10
  • HD Graphics Family driver update (v10.18.15.4248) improves graphics performance and stability on Windows 10.
  • Audio driver update (v6.0.1.7543) improves the Cortana experience on Windows 10.
  • USB driver update (v10.0.10125.31214) improves system power usage.
