Power Options - Add or Remove "Allow wake timers"
How to Add or Remove "Allow wake timers" in Power Options in Windows
The "Allow wake timers" power option setting enables or disables Windows to automatically wake your computer from sleep on a timer for scheduled tasks and other programs.
This tutorial will show you how to add or remove the "Allow wake timers" setting under Sleep in Power Options for all users in Vista, Windows 7, and Windows 8.
Windows 8 automatically disables the Allow wake timers option for AC power (Plugged in) and Battery power when no ACPI Wake Alarm device is detected on the computer, on all default power plans, for mobile computers.
See also: Windows 8 wakes up even if "Allow wake timers" is disabled for the current power source
EXAMPLE: "Allow wake timers" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\238C9FA8-0AAD-41ED-83F4-97BE242C8F20\BD3B718A-0680-4D9D-8AB2-E1D2B4AC806D
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "Allow wake timers" from Power Options
Remove_Allow_Wake_Timers.reg
3. To Add "Allow wake timers" to Power Options
Add_Allow_Wake_Timers.reg
  • Add_Allow_Wake_Timers.reg
  • Remove_Allow_Wake_Timers.reg
