Need more help with Win 8 & 7 dual-boot (UEFI, GPT)
I've followed the above steps and still cannot get a UEFI boot DVD listed. Here is my BIOS screen:
and here is my one time boot screen:
When I boot from the SATA CD the DVD install gets as far as the glowing orbs that combine to make the Windows 7 logo and they freeze.
    Windows 8, OSX 10.6.8
you've described a carbon copy of the issue I'm having - I hope we can get our problem solved
    Windows 7 Home Premium 64 bit
    Self built custom PC
    AMD Phenom II x4 955 Black Edition
    Gigabyte GA-MA790XT-UD4P
    8GB Corsair Red Vengeance DDR3 1600 (@1333MHz)
    XFX AMD Radeon HD 6970 2GB
    Onboard Realtek Azalia
    1x Samsung SyncMaster P2250 DVI
    1. Corsair Force 3 60GB SSD SATA III (in SATAII) - OS, drivers and programs
    2. Western Digital Caviar Blue 500GB SATA II 7,200rpm 16MB Cache - games
    3. Western Digital Caviar Blue 250GB SATA II 7,200rpm 16MB Cache - documents, media, download files
    Corsair TX750W
    Lancool DragonLord PC-K62
    CoolerMaster V8
    Logitech G110
    Logitech MX518
    BT Infinity 2 48Mbps download, 10Mbps Upload
    Logitech G27 Racing Wheel
    Logitech X-140 Speakers
Not quite carbon copy as I believe you have a different laptop but the symptoms are the same.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
You both need to boot the Windows 7 x64 DVD in uEFI mode.
For a test make the startup repair CD & test boot up.
http://www.eightforums.com/tutorials/2855-system-repair-disc-create-windows-8-a.html
I made my CD at a time before I deleted the recovery partition on the HDD (which was empty at the time and a tutorial here recommended deleting it) - should this affect me if I insert the disk?
If it does I can always make another one.
    Corsair TX750W
    CoolerMaster V8
    Logitech G110
    Logitech MX518
The CD is MS Windows 8 startup repair CD, not the Acer Recovery Partition.
    Notebooks x 3
    Desktops x 5
    Towers x 4
ok - will test it out
    Corsair TX750W
    CoolerMaster V8
    Logitech G110
    Logitech MX518
done that - booted up - pressed f12 and selected the dvd drive - took a while but booted from cd but it did - chose UK keyboard - went to use a device but haven't clicked on the disk yet
    Corsair TX750W
    CoolerMaster V8
    Logitech G110
    Logitech MX518
I have created the Windows 8 repair CD as explained and then ensured that the SATA DVD was at the top of the boot priority list.
It started to boot and the screen said "press any key to boot from CD/DVD...". The screen went momentarily blank and then went back to the Samsung logo and has hung there ever since.
I also tried forcing a boot from the one time boot menu (f10) and got the same result as above.
I tried enabling and disabling UEFI secure boot in the BIOS but no luck.
OMG! It took 5 minutes to get to the screen showing the keyboard layout. So the rescue CD seems to be working :) I presume this proves that I can boot from other CDs/DVDs. However why can I not fully boot from the Windows 7 Home 64bit DVD? I'm now wondering if I need to leave the Windows 7 installation process for much much longer, maybe 30 mins to see if it gets past the initial logo animation?
If you're thinking is correct... I will love your brain forever and ever... no homo
    Corsair TX750W
    CoolerMaster V8
    Logitech G110
    Logitech MX518
1) Bad disc burn, remake disc.
2) uEFI/BIOS firmware not set to boot uEFI CD/DVD's.
    Notebooks x 3
    Desktops x 5
    Towers x 4
Is this something we can fix ourselves?
    Corsair TX750W
    CoolerMaster V8
    Logitech G110
    Logitech MX518
Ok so 1 I can test as presumably if the DVD boots from numerous other PCs it should almost negate the "bad burn" scenario.
Point 2: I have tried turning on and off the uEFI options in the BIOS. How do I know that my DVD is uEFI however? I have two mediums currently:
1. an original ISO provided by Microsoft of Windows 7 Home Edition 64 SP1. Can I tell whether this is uEFI?
and
2. A Patched Windows 7 installation uEFI USB stick.
just an update: Starting Windows screen is still frozen after the time I posted about trying it out after your (krikey) idea... I was so hoping something would happen :(
    Corsair TX750W
    CoolerMaster V8
    Logitech G110
    Logitech MX518
Only on a uEFI PC.
original DVD provided by Microsoft of Windows 7 Home Edition 64 SP1 will be uEFI.
May be bad burn.
Yes, set the uEFI/BIOS firmware to boot uEFI CD/DVD's.
theog said:
3) Reset BIOS to default, and reboot to BIOS make sure Secure Boot is disabled.
NOTE: Check your manufacturer's uEFI BIOS manual for settings.
    Notebooks x 3
    Desktops x 5
    Towers x 4
Ok so I followed this tutorial once more: http://www.eightforums.com/tutorials/15458-uefi-bootable-usb-flash-drive-create-windows.html
I also ensured "confirm-SecureBootUEFI" returned false before trying to get a UEFI device in the one time boot menu.
I also tried toggling Fast BIOS on and off.
I've also tried the USB stick on three different USB slots on the Samsung laptop.
I've tried booting the USB stick from an acer aspire one laptop and it boot successfully and gets beyond the animated windows 7 logo so the USB stick is fine.
All thats listed in the one time boot menu (f10) is the devices:
1. SATA CD:: Matshitadvd-ram -----
2. WIndows Boot Manager
3. SATA HDD:: -------
So the USB stick is not being recognised by this Laptop as a bootable device. This is the third USB stick I have used.
Only on a uEFI PC.
May be bad burn.
No option to do that - even updated the BIOS too!
    Corsair TX750W
    CoolerMaster V8
    Logitech G110
    Logitech MX518
Ive just tried having the windows 7 Install USB insytalled and then forcing the BIOS to ONLY see the USB HDD and disabling all other boot medium. Ive then tried to use the recovery F4 keypress to see if this will force widnows 7 to load from the USB.
No Luck :( It simply boots into the rescue partition on the internal HD.
If you have no option to boot uEFI CD/DVD in the uEFI/BIOS firmware, your Acer Recovery Disc will not boot to reinstall.
    Notebooks x 3
    Desktops x 5
    Towers x 4
