How to Boot from a USB Drive on Surface
Information
This tutorial will show you how to boot from a USB drive on Surface RT, Surface 2, Surface Pro, Surface Pro 2, and Surface Pro 3.
Note
This is a per usage option that will not configure Windows or Surface to always boot from the USB drive.
You will need a bootable UEFI flash drive to be able to boot from it using the method in this tutorial.
Boot from USB Drive within Windows 8.1 or 8.1 RT on Surface
1. For how, see: How to Boot from a USB Drive within Windows 8 and 8.1
To Boot Directly from USB Drive on Surface
1. While Surface is turned off, connect a bootable USB drive to the USB port.
2. Press and hold the volume-down button. (see screenshot below)
3. Press and release the power button. (see screenshot below)
4. When the Surface logo appears, release the volume-down button. Surface will now boot from the USB drive. (see screenshot below)
- How to Boot from a USB Drive within Windows 8 and 8.1
- Enable or Disable Always Automatically Boot PC from USB Drive in Windows To Go Startup Options
- How to Create a Windows To Go Startup Options Shortcut in Windows 8 and 8.1
- How to Create an Advanced Startup Options Shortcut in Windows 8 and 8.1
- How to Create a Recovery PC settings Shortcut in Windows 8.1
- How to Create a Bootable USB or DVD with the Windows 8 or 8.1 ISO
- How to Create a Bootable UEFI USB Flash Drive for Installing Windows 7, 8, or 8.1
- How to Boot to Advanced Startup Options in Windows 8 and 8.1
- How to Boot to "System Recovery Options" in Windows 8 and 8.1
- How to Boot to UEFI Firmware Settings from inside Windows 8 and 8.1
- How to Enable or Disable the New Windows 8 Startup Options Boot Menu
- How to Download and Use Official Recovery Image for your Surface
