Power - Add Cascading Desktop Context Menu in Windows 8
How to Add a Power Cascading Desktop Context Menu in Windows 8 and 8.1
This will show you how to add or remove a cascading (expandable) Power menu to the desktop context menu for all users to quickly Lock, Switch user, Sign out (log off), Sleep, Hibernate, Hybrid Shut down, Full Shut down, Restart, or Restart to Boot Options in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1.
You must be signed in as an administrator to be able to add or remove the "Power" context menu from the desktop.
If you would like to have this customized for you, then please post what you would like in the Power context menu instead. I'll be happy to whip it up for you. :)
  • Sleep - You will need to disable hibernate for this to sleep instead of hibernate.
  • Hibernate - You will need to enable hibernate for it to work. It is by default.
  • Hybrid Shut down - You will need to enable hibernate and have fast startup turned on for this to do a hybrid shut down instead of a full shut down. It is by default.
  • Full Shut down - This will do a normal full shut down no matter if you have fast startup turned on or off.
  • Slide to Shut down - Windows 8.1 introduces this option to be able to shut down your PC by simply dragging a screen down, or sliding a touch screen down.
Tip   Tip
If you would prefer to add Lock, Switch user, Sign out, Shut down, or Restart as a separate desktop context menu item instead, then see the Related Tutorials links at the bottom of this tutorial.
EXAMPLE: "Power" Cascading Context Menu
1. To Add "Power" to the Desktop Context Menu
A) Click/tap on the Download button below to download the file below, and go to step 3 below.​
Add_Power_to_Desktop_Context_Menu.reg
2. To Remove "Power" from the Desktop Context Menu
Remove_Power_from_Desktop_Context_Menu.reg
3. Save the REG file to your desktop.
4. Double click/tap on the REG file to merge it, and click/tap on Run, Yes (UAC), Yes, and OK when prompted to approve the merge.
5. When finished, you can delete the downloaded .reg file if you like.
6. Right click on your desktop to see the change.
NOTE: You can press the Windows+ D keys to go to the desktop.
The Switch User option will only work in the Windows 8 Pro and Windows 8 Enterprise editions by default.
If you have the Windows 8 edition, then you will need to also do this below for the Switch User option to work.
  • Click on the Download button below to download the tsdiscon.zip file.
  • Save the tsdiscon.zip file to your desktop.
  • Open the tsdiscon.zip file, and extract (drag and drop) the tsdiscon.exe file to your desktop.
  • Unblock the extracted tsdiscon.exe file.
  • Move the tsdiscon.exe file into the C:\Windows\System32 folder.
  • If prompted, click/tap on Continue and Yes (UAC) to approve.
  • tsdiscon.zip
  • Add_Power_to_Desktop_Context_Menu.reg
  • Remove_Power_from_Desktop_Context_Menu.reg
Very good - is it possible to add "sleep" as an option??
    WIN7 Home Premium 64-bit
    Homebuilt
    Intel I7 920
    Asus P6T-Se
    6Gb
    Sapphire HD5770
    On-board
    ASUS VW246H, Samsing Syncmaster 2233, Samsung Syncmaster T200HD
    2 x 500Gb
    Coolermaster Silent Pro M700
    NOX
    Logitech Marble
    10Mbps
    Dell Inspiron 1501 with Win 8 CP 32 Bit - flying along!
Thanks Shawn. Much nicer than the individual ones.
    Hewlett-Packard/G62 Notebook
    Hewlett-Packard 1425
    8 GB DDR3
    Intel(R) HD Graphics
    Realtek High Definition Audio
    Builtin
    1TB Iomega NAS.
    20Mb/sec
You're most welome guys. :)
@MadHorseman
Added. :)
Thanks Brink, Win+I is quick enough really!
    Homebuilt
    Intel I7 920
    Asus P6T-Se
    6Gb
    Sapphire HD5770
    On-board
    2 x 500Gb
    NOX
    Logitech Marble
    10Mbps
Tutorial updated for separate hybrid and full shut down options. :)
Looks like the /full switch for the shutdown command was removed in Windows 8 Release Preview. Tutorial updated for it. To update, you will just need to download the updated Add_Power_to_Desktop_Context_Menu.reg file in the tutorial and merge it.
Awesome - great job Brink - thx
    W7x64/W8x64
    AMD PHENOM II X6 1090T
    GIGABYTE GA-890GPA-UD3H
    RAMD38G1600K-V9 DDR3-1600 (2x4G) 9-9-9
    POWERCOLOUR R6950 2GB
    BenQ-GL2440 (x2)
    OCZ Vertex2 120GB (currently busted, awaiting replacement, hence the investigating into W8)
    ST2000DL003-9VT166 (x2) [2TB SATA-3]
    THERMALTAKE TOUGH POWER XT 77SW
    THERMALTAKE ARMOR PLUS
    Noctua NH-D14
    Microsoft Natural Egrnomic 4000 v1
    Deathadder V2 Left Hand Precision Gaming Mouse Razer
    100Mbps/40Mbps [Skymesh NBN]
You're most welcome Brent, and welcome to Eight Forums. :)
Did Not Work For Me . Please Help :(
    Windows 8 RTM Enterprise Edition x64
    Windows
    AMD Phenom 9950 Quad-Core ( Black - Edition )
    Gigabyte
    4 GB - DDR3
    Sapphire AMD HD 7770 OC Edition 1 GB GDDR5
    Dont Know
    Samsung 18 inch LCD
    1600x900
    Seagate 1 Tb Internal + 1 Tb Western Digital External
    Cooler Master 750 W
    Cooler Master Cabinet
    Dont Know
    Logitech
    Logitech
    1 Mbps Internet , 30 Mbps LAN
Hello EvilCraze,
What part of it didn't work? Any error messages?
Were you able to download the add .reg file and merge it?
boom.png I Dont get The Menu When I Click On Power Option
    Windows
    Gigabyte
    4 GB - DDR3
    Dont Know
    Samsung 18 inch LCD
    1600x900
    Cooler Master 750 W
    Dont Know
    Logitech
    Logitech
EvilCraze,
Odd, it works perfectly fine for me with the same Windows 8 64-bit as you have. Do you have this issue with any other context menu not expanding out?
What language is your Windows in?
If not English, then double check the registry entries below in the .reg file to see if the name of the default keys and entries match yours with the language difference.
Windows Registry Editor Version 5.00
; Created by: Shawn Brink
; [URL]http://www.eightforums.com[/URL]
; Tutorial: [URL]http://www.eightforums.com/tutorials/5215-power-add-cascading-desktop-context-menu-windows-8-a.html[/URL]
[HKEY_CLASSES_ROOT\DesktopBackground\Shell\Power]
"MUIVerb"="Power"
"SubCommands"="Lock;SwitchUser;SignOut;Sleep;Hibernate;HybridShutdown;ShutDown;Restart"
"icon"="shell32.dll,-221"
"Position"="bottom"
; Lock
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\Lock]
@="Lock"
"icon"="shell32.dll,-48"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\Lock\command]
@="rundll32.exe user32.dll, LockWorkStation"
; Switch User
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\SwitchUser]
@="Switch User"
"icon"="imageres.dll,-88"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\SwitchUser\command]
@="tsdiscon.exe"
; Sign out
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\SignOut]
@="Sign out"
"icon"="shell32.dll,-45"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\SignOut\command]
@="shutdown.exe -L"
; Shut down
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\ShutDown]
@="Full Shut down"
"icon"="shell32.dll,-28"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\ShutDown\command]
@="shutdown.exe -s -f -t 00"
; Hybrid Shut down
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\HybridShutdown]
@="Hybrid Shut down"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\HybridShutdown\command]
@="Shutdown -s -f -hybrid -t 00"
; Restart
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\Restart]
@="Restart"
"icon"="shell32.dll,-290"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\Restart\command]
@="shutdown.exe -r -f -t 00"
; Sleep
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\sleep]
@="Sleep"
"icon"="powercpl.dll,-514"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\sleep\command]
@="rundll32.exe powrprof.dll,SetSuspendState Sleep"
; Hibernate
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\hibernate]
@="Hibernate"
"icon"="imageres.dll,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\hibernate\command]
@="Shutdown -h"
Hello Highlander,
What language is your Windows 8? If not English, then that may be an issue.
Do you have UAC enabled to at least the default level?
Do you have issues with any other context menus not expanding?
Could you also post screenshots showing what you see?
Many thanks for the info Brink, Works perfectly
    Acer Aspire 5551
    AMD Athlon ii X2
    6 GB
    ATI Mobility Radeon HD 4250
You're most welcome Eric, and welcome to Eight Forums. :)
You're most welcome Ant, and welcome to Eight Forums. :)
Well... I have UAC to a minimum, otherwise metro apps will not run...
When I hover over... it will not expand... other context menus expand fine.
    W8
