Network Connection Settings Shortcut - Create Windows 8.1
How to Create a Network Connection Settings Shortcut in Windows 8.1
Network -> Connections in PC settings allows you to edit, manage, and view connection settings of your added networks on the PC.
This tutorial will show you how to create or download a Network Connection Settings shortcut that opens directly to PC settings to "view connection settings" in Windows 8.1 and Windows RT 8.1.
EXAMPLE: View Connection Settings
To Download a "Network Connection Settings" Shortcut
Network_Connection_Settings_Shortcut.zip
3. Open the .zip file and extract (drag and drop) the shortcut to your desktop.
4. Unblock the extracted shortcut.
6. When finished, you can delete the downloaded .zip file if you like.
To Manually Create a "Network Connection Settings" Shortcut
If you do not have a US English Windows 8.1 installed, then you will need to change the en-US folder name in the command below for the folder name with your language instead for this to work.
%windir%\explorer.exe %localappdata%\Packages\windows.immersivecontrolpanel_cw5n1h2txyewy\LocalState\Indexed\Settings\en-US\AAA_Settings_Group_VPN.settingcontent-ms
3. Type Network Connection Settings for the name, and click/tap on the Finish button. (see screenshot below)
4. Right click or press and hold on the new Network Connection Settings shortcut, and click/tap on Properties.
%SystemRoot%\system32\imageres.dll
  • Network_Connection_Settings_Shortcut.zip
