Touch Keyboard Click Sound - Turn On or Off in Windows 8
How to Turn On or Off to Play Click Sounds as you Type on Touch Keyboard in Windows 8 and 8.1
This tutorial will show you how to turn on or off to play key click sounds as you type on the on-screen touch keyboard in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1.
On the Surface tablet, this setting would also include the key click sounds made while typing on a touch cover accessory.
This does not affect the clicking sound for the On-Screen Keyboard.
By default, the on-screen touch keyboard will only appear automatically on a touch PC when you tap in a text field in a modern UI screen or modern app. When you want to type using the on-screen keyboard with Surface, fold back the cover or remove it. Next, tap in a text field or other area where you can type. The keyboard appears automatically.
They don't automatically appear if you’re using a desktop app. Instead, you need to tap or click the Touch keyboard icon on the right side of the taskbar.
EXAMPLE: Touch Keyboard in Windows 8*
EXAMPLE: Touch Cover for Surface tablet
Set to Play Touch Keyboard Click Sound in Windows 8 and RT
1. Open PC Settings.​
2. Click/tap on General on the left side, and do step 3 or 4 below for what you would like to do. (see screenshot below)​
3. Turn On to Play Click Sound as you Type on Touch Keyboard
A) On the right side under Touch keyboard, move the slider to the right to turn on Play key sounds as I type, and go to step 5 below.​
4. Turn Off to Play Click Sound as you Type on Touch Keyboard
A) On the right side under Touch keyboard, move the slider to the left to turn off Play key sounds as I type, and go to step 5 below.​
5. When finished, you can close PC settings if you like.​
Set to Play Touch Keyboard Click Sound in Windows 8.1 and RT 8.1
1. Open PC Settings, and click/tap on PC and devices on the left side. (see screenshot below)​
2. Click/tap on Typing on the left side, and do step 3 or 4 below for what you would like to do. (see screenshot below)​
Set to Play Touch Keyboard Click Sound using a REG File
NOTE: This option will work on all Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1 PCs and tablets.
HKEY_CURRENT_USER\Software\Microsoft\TabletTip\1.7
EnableKeyAudioFeedback DWORD
0 = Disable click sound
1 = Enable click sound
2. Turn On to Play Click Sound as you Type on Touch Keyboard
Turn_On_Touch_Keyboard_Sounds.reg
3. Turn Off to Play Click Sound as you Type on Touch Keyboard
Turn_Off_Touch_Keyboard_Sounds.reg
4. Save the .reg file to your Desktop.​
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.​
  • Turn_Off_Touch_Keyboard_Sounds.reg
  • Turn_On_Touch_Keyboard_Sounds.reg
0 = Enable click sound
1 = Disable click sound
1 = Enable click sound (audio feedback)
0 = Disable click sound (audio feedback)
:thumbsup:
