I've started having problems when logging on to my Dell Laptop running Windows 8.1 Pro. The icons are slow to appear after logon and I can't select icons with the touchpad. The screen then flashes blue and the icons reload after which the laptop operates normally.
I get an Error Event ID 1000 copied below which seems to be the problem. It points to a faulting module twinui.dll. Have you any advice how to solve this problem?
Level Date and Time Source Event ID Task Category
Error 27/09/2015 07:17:02 Application Error 1000 (100) "Faulting application name: Explorer.EXE, version: 6.3.9600.17667, time stamp: 0x54c6f7c2
Faulting module name: twinui.dll, version: 6.3.9600.17415, time stamp: 0x54503c45
Exception code: 0x80270249
Fault offset: 0x00000000002f497f
Faulting process ID: 0xe08
Faulting application start time: 0x01d0f8ec1e23ccaa
Faulting application path: C:\WINDOWS\Explorer.EXE
Faulting module path: C:\WINDOWS\system32\twinui.dll
Report ID: 5d5dc171-64df-11e5-84b3-b82a729fff82
Faulting package full name:
Faulting package-relative application ID: "
