Solved Home Pages will not save
huey714
Featherville
20
My laptop will mot save my home pages if I turn it off. Any ideas whats going on??
    Toshiba S55-A5275
    Norton 360
mick823
Chicago USA
84
Try uninstalling the Firefox Browser and reinstalling. There is a way to save your profile but I wouldn't recommend it in this case. Start fresh with a new install. If you still have a problem you can get rid of the residual profile information by navigating to the C:\Users\your_user_name\AppData\Roaming\ and deleting the Mozilla folder where the Firefox information resides. Delete the folder first and then do the re-installation.
In summary:
1. Reinstall Firefox
2. check to see if the problem is solved.
If Not:
1. uninstall Firefox
2. Delete Mozilla Folder as described
3. Reinstall Firefox
4. Check to see if problem resolved.
Post back with your results.
    Windows 7 Pro and Windows 8.1 Pro 32 bit and 64 bit
    Lenovo and Dell
    Intel i3
Jacob W
2
All your browsers can not save homepage? Reinstalling may solve your problems.
But if stubborn browser hijacker alters your registry, normally it is hardly to save homepage manually.
Also you can try Yet Another Cleaner,set homepage as the following steps yac07.png
    win 8
    Windows 7 Ultimate x64
    i3
    asus
    4gb
huey714
Featherville
20
In summary:
If Not:
Thanks!! Re-installing Foxfire did the trick.
    Toshiba S55-A5275
    Norton 360
mick823
Chicago USA
84
You are welcome. Don't forget to to mark your post as solved.
    Lenovo and Dell
    Intel i3
