You sir are AWSOME!
- 8.1
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Aspire XC-603G
- CPU
- Qaud Core
- Memory
- 8g
- Graphics Card(s)
- Intel
- Browser
- Firefox
- Antivirus
- AVG
So I successfully downgraded this PC after a bit (LOT) of research and tinkering. I’ve provided the steps I followed below.
THANK YOU THANK YOU... about 3 VERY frustrating days and many attempts at different BIOS updates and the googled myself to death. I now have debian installing.
Acer AXC-603 Downgrade to windows 7 Instructions
STEP 1 - Downgrade BIOS/UEFI
WARNING: DO THIS STEP AT YOUR OWN RISK. IF SOMETHING GOES WRONG HERE, YOU RISK PERMANENTLY DAMAGING YOUR COMPUTER. I MODIFIED THE BATCH FILES TO IGNORE CHECKING ROM ID. IT WORKED PERFECTLY FOR ME BUT THERE ARE NO GUARANTEES THAT IT WILL WORK FOR YOU. I AM IN NO WAY RESPONSIBLE IF THE FOLLOWING INSTRUCTIONS DAMAGE YOUR COMPUTER.
This step depends on what operating system you currently have on the machine. You will need the files provided HERE (Please download a local copy. I will try to keep this available as long as i can but cant make any promises for the distant future)
Step1-A – IF NO operating system
If you have a recovery disk you can also try using it or the recovery partition (Alt+F10 at boot). If that doesn't work, the easiest way to do this is to download the evaluation copy of windows 8 from Microsoft and do a fresh installation.
After windows 8 is installed follow steps from Step1-B.
Step1-B – IF YOU ARE IN WINDOWS 8
Open the “Bios WIN” folder from the files provided HERE. Navigate to the “WIN” directory. Right click on Flash.bat and run as administrator (can also be run from an elevated command prompt from within windows)
You should see a command prompt popup and it will now downgrade your BIOS.
If you manage to get through this step, you've won 90% of the battle so cheer UP!
Step1-C – IF YOU ARE IN DOS / FREEDOS
I haven’t tried this personally but the following should theoretically work
Use another machine to download the provided files. Burn them on a CD/DVD that is accessible from dos.
Boot to dos and use the “cd” command to navigate to the “Bios Dos” directory
Execute Flash.bat
STEP 2 - BIOS/UEFI Settings
After flashing the bios press “Del” while booting to make sure the following settings are set
Set secure boot to disabled
Set CSM mode to always
Boot Priority – As per your preference.
Step 3 - Install WIN 7
Boot from windows 7 DVD or USB to install windows 7. I personally used a DVD to complete the process so I can verify that is working.
Hard disk Partitions – If you have left over partitions from previous installations, delete all of them and creating new partitions. You can try installing over the old partitions but I personally haven’t tested this.
Step 4 - Install Drivers
Install the drivers provided in the link
STEP 5 – ENJOY WINDOWS 7
CREDITS:
http://www.eightforums.com/tutorials/13326-downgrade-windows-8-windows-7-a.html
Acer Aspire XC-603 Desktop PC - Desktops | Ebuyer.com
I'm pretty familar with working around most computers but this one has stumpped me...
Acer Aspire X AXC-603G-UW31
Had Windows 8 on it. Want to add 7.
So far I was able to wipe the drive clean by hooking it up to another PC using EASEUS Partition manager.
I put the HD back in the Aspire and my Windows 7 disc in the DVD drive. The same error keeps coming up.
"Reboot and Select porper Boot Device or Insert Boot Media in Selected Device and press a key"
Boot priority is set to the DVD. Also when I hit F12 for boot manager it sends me to the error as well.
In Bios there isn't many options like a normal computer. Kind of a cheaper computer so options are cheap as well.
Any ideas?
Any ideas?
Hi! I just want to ask if you have got your problem solved?
I have an AXC-603-EB11, BIOS is P11-A2, I tried to install Windows 7 64 bit, but it doesn't work out, I guess there's something wrong with BIOS. which BIOS version did you upgrade or downgrade to make it work?
Thank you!
Execute Flash.bat
CREDITS:
Hello, thank you for your great info!!
I have just purchased an Acer Aspire XC-603-EB11, current BIOS is P11-A2, it seems that it does not support Windows 7 installation, I used 64 bit since I got 8G ram.
So, I just wonder which BIOS version did you use to make it work? Should I try the latest version?
I need a bit more information, thank you very much!!
Execute Flash.bat
CREDITS:
Yep...like rfrayer mentioned, flash the bios and it should let you install windows 7
no point in upgrading to the latest bios from the acer website. I tried that already and it ends up locking your pc down even more.
Good Luck!
Good Luck!
Okay, so My question is, which version of BIOS is good to install? I just downloaded the latest version, but I haven't tried installing it.
Which version of BIOS, plz!!!
Thanks for the great solution... got the BIOS downgraded, Windows 7 ultimate installed no problems.
The Windows 7 video driver does not work for me however... I get the message "The setup failed to install one or more device drivers. Setup will now exit". I have a AXC-603G-UW12.
I did try using the windows 7 drivers for other PCs in the same 60x class... no luck. Any ideas?
If your Video card is whats causing the issue then you can disable it, causing Windows to use the default 'Standard VGA Adapter'. Once you have booted to your desktop you can download & install the latest drivers.
See here: How to Access Device Manager During the Installation of Windows 7
Hi, i have a problem with my PC, i tried to downgrade the BIOS and changed the settings but when the loading screen of Windows finish, a blue screen pop up and it says: " the BIOS in this system is not fully ACPI compliant". i dont know if i did something wrong. Is anyone with the same problem?
BTW i have Windows 8.1.
glad windows 7 worked out for you!Thanks amohani, i was doing wrong. To downgrade the bios i had to open Command prompt and execute the file. now i have windows 7 and i have issues with the video driver
This one worked for me: Win64_153322.exe... i have issues with the video driver
