Solved BSOD while installing Realtek Audio
victoryo
Hello,
This morning i did a clean install of Windows 8 on my new Laptop
and just had a BSOD while i was installing latest Realtek drivers.
Hope someone can figure out wat's causing it :)
Thank-you
Your BIOS dates from 2011. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website). Be sure to update ALL controllers on the motherboard! I STRONGLY suggest not using controller drivers older than mid-2012 with SSD's.
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: https://www.eightforums.com/bsod-cr...-pc-reboots-when-waking-sleep.html#post169956
27 Feb 2013 - I'm starting to see much better reliability with SSD's using current (mid-2012 and later) storage drivers. I have withdrawn my objections to using these devices in everyday systems.
Your storage controller (the Intel one) dates from 2010 - it must be updated.
ASMMAP64.sys Thu Jul 2 05:13:26 2009 (4A4C7A36)
LENOVO ATK Hotkey ATK0101 ACPI UTILITY
http://www.carrona.org/drivers/driver.php?id=ASMMAP64.sys
iaStor.sys Mon Sep 13 21:23:32 2010 (4C8ECE94)
Intel Storage drivers
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
HECIx64.sys Tue Oct 19 19:33:43 2010 (4CBE2AD7)
Intel Management Engine Interface
SynTP.sys Fri Mar 4 13:41:33 2011 (4D71325D)
Synaptic Touch Pad Driver
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
atkwmiacpi64.sys Tue Sep 6 21:44:52 2011 (4E66CC94)
ATK WMIACPI Utility
http://www.carrona.org/drivers/driver.php?id=atkwmiacpi64.sys
Rt630x64.sys Wed Oct 19 08:12:55 2011 (4E9EBEC7)
Realtek PCI/PCIe Adapters
Analysis:
[font=lucida console]**************************Wed Mar  6 05:02:44.091 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030613-6468-01.dmp]
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]0 days 0:19:04.781[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!IopProcessWorkItem+0 )[/B]
BugCheck [B]E1, {fffff801fa6756e4, 1, fffffa800a73c910, fffffa800a73c910}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000E1]WORKER_THREAD_RETURNED_AT_BAD_IRQL (e1)[/url]
Arguments:
Arg1: fffff801fa6756e4, address of worker routine (do ln on this to find guilty driver)
Arg2: 0000000000000001, IRQL returned at (should have been 0, but isn't).
Arg3: fffffa800a73c910, workitem parameter
Arg4: fffffa800a73c910, workitem address
BUGCHECK_STR:  0xE1
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0xE1_nt!IopProcessWorkItem[/B]
CPUID:        "Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz"
MaxSpeed:     2300
CurrentSpeed: [B]2295[/B]
  BIOS Version                  K53SV.320
  BIOS Release Date             11/11/2011
  Manufacturer                  ASUSTeK Computer Inc.
  Product Name                  K53SV
[/font]
3rd Party Drivers:
[COLOR=RED][B]ASMMAP64.sys                Thu Jul  2 05:13:26 2009 (4A4C7A36)[/B][/COLOR]
[COLOR=RED][B]iaStor.sys                  Mon Sep 13 21:23:32 2010 (4C8ECE94)[/B][/COLOR]
[COLOR=RED][B]HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)[/B][/COLOR]
[COLOR=RED][B]SynTP.sys                   Fri Mar  4 13:41:33 2011 (4D71325D)[/B][/COLOR]
[COLOR=RED][B]atkwmiacpi64.sys            Tue Sep  6 21:44:52 2011 (4E66CC94)[/B][/COLOR]
[COLOR=RED][B]Rt630x64.sys                Wed Oct 19 08:12:55 2011 (4E9EBEC7)[/B][/COLOR]
athrx.sys                   Wed Mar 21 23:26:22 2012 (4F6A9BDE)
RTKVHD64.sys                Tue Jun 19 04:50:56 2012 (4FE03D70)
IntcDAud.sys                Tue Jun 19 10:40:51 2012 (4FE08F73)
igdkmd64.sys                Wed Dec 12 19:42:26 2012 (50C92472)
nvlddmkm.sys                Sat Feb  9 18:13:08 2013 (5116D804)
[/font]
http://www.carrona.org/drivers/driver.php?id=athrx.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
Thank-you. Bios version is the Latest, i already updated it before installing Windows.
Altough it is from 2011 there is no newer version :(
But i've indeed saw the post where most things that can cause a BSOD on windows 8 with a SSD are called
and saw that updating the SATA AHCI drivers is important so I already updated those intel drivers.
I haven't had any BSOD for 1,5 days now so I am very happy.
THe other old drivers you mentiont i tried to update. But my laptop is an Asus so I don't know
if I need to install or update that Lenovo driver. Also the Asus ATKACPI package I have at the moment is the latest available.
Oke, lol. While i was typing previous message and updating the realtek Lan driver i had a BSOD xD
Finally got it updated by doing it from computer management and browse my computer to the correct folder.
There is a problem i think with the automatic installer of the realtek Lan driver for windows 8.
The Synaptic drivers i couldn't update from the site. So i grabbed the latest from Asus and they work great.
Also i tried to install latest Realtek HD audio drivers again from the Realtek site.
And this time i didn't had a BSOD and they are working fine now!
Can you check my drivers once again? I will create a new log with the last BSOD from uninstalling
the realtek audio drivers!
Thanks in advantage!
Sorry, but I didn't receive notification of your reply.
All of the recent BSOD's were STOP 0x7E's and all blamed your video drivers.
But, I found a trace of Daemon Tools in the dump files. This program causes BSOD's on Windows systems. Please follow these instructions to remove it:
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
RTKVHD64.sys Tue May 17 05:00:03 2011 (4DD23913)
Realtek High Definition Audio Function Driver
ATK WMIACPI Utility
Analysis:
[font=lucida console]**************************Thu Mar  7 14:20:28.502 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-6250-02.dmp]
System Uptime:[B]0 days 0:02:10.194[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+3ad8b4 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff88007ea28b4, fffff88002f402b8, fffff88002f3faf0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x1000007E]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/url]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff88007ea28b4, The address that the exception occurred at
Arg3: fffff88002f402b8, Exception Record Address
Arg4: fffff88002f3faf0, Context Record Address
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nvlddmkm+3ad8b4[/B]
MaxSpeed:     2300
  Product Name                  K53SV
**************************Thu Mar  7 14:02:40.339 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-6406-01.dmp]
System Uptime:[B]0 days 0:03:35.031[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff88006ea48b4, fffff88002f162b8, fffff88002f15af0}[/B]
Arguments:
Arg2: fffff88006ea48b4, The address that the exception occurred at
Arg3: fffff88002f162b8, Exception Record Address
Arg4: fffff88002f15af0, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2300
  Product Name                  K53SV
**************************Thu Mar  7 13:57:46.856 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-6218-01.dmp]
System Uptime:[B]0 days 0:01:25.548[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff880071f08b4, fffff88002f162b8, fffff88002f15af0}[/B]
Arguments:
Arg2: fffff880071f08b4, The address that the exception occurred at
BUGCHECK_STR:  AV
MaxSpeed:     2300
  Product Name                  K53SV
**************************Thu Mar  7 13:56:00.460 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-6031-01.dmp]
System Uptime:[B]0 days 0:02:08.152[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff880073f68b4, fffff88000ffa2b8, fffff88000ff9af0}[/B]
Arguments:
Arg2: fffff880073f68b4, The address that the exception occurred at
Arg3: fffff88000ffa2b8, Exception Record Address
Arg4: fffff88000ff9af0, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2300
  Product Name                  K53SV
**************************Thu Mar  7 13:53:31.418 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-6437-01.dmp]
System Uptime:[B]0 days 0:05:02.109[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8800720b8b4, fffff88002f4e2b8, fffff88002f4daf0}[/B]
Arguments:
Arg2: fffff8800720b8b4, The address that the exception occurred at
Arg3: fffff88002f4e2b8, Exception Record Address
Arg4: fffff88002f4daf0, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2300
  Product Name                  K53SV
**************************Thu Mar  7 13:48:06.977 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-6250-01.dmp]
System Uptime:[B]0 days 19:45:15.015[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff88007e6f8b4, fffff8801ab992b8, fffff8801ab98af0}[/B]
Arguments:
Arg2: fffff88007e6f8b4, The address that the exception occurred at
Arg3: fffff8801ab992b8, Exception Record Address
Arg4: fffff8801ab98af0, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2300
  Product Name                  K53SV
[/font]
3rd Party Drivers:
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
SynTP.sys                   Fri Jun 15 09:34:48 2012 (4FDB39F8)
Smb_driver_Intel.sys        Fri Jun 15 09:35:29 2012 (4FDB3A21)
dump_iaStorA.sys            Mon Nov 19 15:09:40 2012 (50AA9204)
Rt630x64.sys                Thu Dec 27 19:04:06 2012 (50DCE1F6)
VBoxNetFlt.sys              Wed Feb 20 10:34:52 2013 (5124ED1C)
VBoxUSBMon.sys              Wed Feb 20 10:34:53 2013 (5124ED1D)
VBoxNetAdp.sys              Wed Feb 20 10:34:53 2013 (5124ED1D)
VBoxDrv.sys                 Wed Feb 20 10:36:24 2013 (5124ED78)
[COLOR=RED][B]RTKVHD64.sys                Tue May 17 05:00:03 2011 (4DD23913)[/B][/COLOR]
[/font]
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
http://www.carrona.org/drivers/driver.php?id=VBoxNetFlt.sys
http://www.carrona.org/drivers/driver.php?id=VBoxUSBMon.sys
http://www.carrona.org/drivers/driver.php?id=VBoxNetAdp.sys
http://www.carrona.org/drivers/driver.php?id=VBoxDrv.sys
Sorry, forgot to reply.
But all my BSOD's are fixed and Laptop is running as the speed of light with the SSD :P
This is what i did:
I found on the internet a Bios version 324 that was leaked from a RMA return and was newer
then the version 320 available on the website. So i flashed that bios.
After that i Secure Erased my SSD with Gparted live cd.
After that i did a clean windows 8 installation. When it was done i checked the system management
for new hardware and was crossing my fingers that it wouldn't BSOD. And it didn't! =D
So I was dancing!!!!
After that i installed every driver by searching the latest one on google and manufactures sites and checked
everytime if I was still able to search for changed hardware!
At the end I have a up and running system without BSODS and with all latest drivers that installed all
succesful without any BSOD or issue =D!
Thanks for the support
