chev65
Closed
- Location
- Beach house paradise
Yeah it has done this since the scan just how you describe, and the only way I can connect again is by restarting the pc (disconnecting the wireless adapter, unplugging the router etc doesn't do anything to help, but restarting the pc fixes it) I'll put the DNS settings into the router, hopefully that'll help. Again appreciate the help![]()
Ok if this doesn't help then it's time to remove Avast using the removal tool as it's the most likely culprit at this point.
avast! Uninstall Utility | Download aswClear for avast! Removal
