  1. #11
    Alright, this should not be too difficult from here. What I would need from you is to right click on that Multimedia Audio Controller. Choose Properties then go to Details tab. Change the dropdown to say Hardware ids. Then copy/paste the results here.
    I will find you the correct driver or edit one to hopefully work, if that is not possible.
    No, disabling your other audio device is not necessary at all. They both can co-exist happily on the same system.
  2. #12
    ...and contineously i get the messageClick image for larger version
  3. #13
    PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00
    PCI\VEN_1102&DEV_0005&CC_040100
    hopefully enough
  4. #14
    Microsoft had this driver on their server but it is not for your EXACT hardware id so that is why they did not give it to you with Windows Update.
    I fixed it so it works for you. Extract my download to a folder.
    Right click Multimedia Audio Controller as before in the device manager. Choose Update driver software. Browse my computer. Let me pick. Have disk. Browse.
    Now find wdma_emu.inf in the folder you extracted to. Click on it. Hit next then ok and it will install.
    Creative.zip
    If that alone does not install for you like that, then copy/paste my attachment contents from the below link over the .inf in that above extract folder first:
    Creative Sound Blaster X-fi Xtreme Audio card Attached Files
  5. #15
    just starting ...
  6. #16
    let me pick requirates to click on something from list. multimedia audio controller is not listed, so what should i click on?
  7. #17
    Quote Originally Posted by mattfly View Post
    Click on have disk now, then browse. Now find and click on the .inf.
    If that install fails, then like I said above, patch the .inf with the 2nd download as I've shown to do and try again.
  8. #18
    saying shortly, you are a genious. thanks a lot mate. i got it worked now. imagine that i wanted to come back to 7 just because that issue. thanks again.
    btw, all apps linked to sb will work normally? i mean console, etc?
  9. #19
    Thanks for the compliment. Yes, everything should work as normal and well.
    I am unfamiliar with that hardware, but if you notice missing apps or whatnot that you used to have, you can try installing again from the link in the original post of this thread.
    Since it is not meant for you card, it will not touch the driver at all and may go on to install software. Or you could try installing just that particular app inside the download folder if it has it's own setup.exe or .msi file. Or you could even try copying over folder(s) from other operating systems that are working and just try running programs to see if they are able to without even an install.
    Just some ideas...
    Enjoy!
  10. #20
    if i encounter some problems in the future i know who can help me take care buddythanks again
Page 2 of 10 FirstFirst 1234 ... LastLast
I have a Turtle Beach Audio Advantage Micro USB Sound Card. It has S/PDIF Optical Out which works great with my surround sound system. I tried installing the drivers on Windows 8 Pro x64 but it keeps saying "Please plug-in USB Audio Device device!". When I go to Device Manager and manually try...
I have a titanium x-fi pci-e sound card on windows 8 pro. It works fine but I cannot save my own settings for sound card. Whenever I restart the computer it reverts back to default. Is there any solution this odd behavior ? Some people say that they cannot even hear any sound out of sound cards....
