I did, yeah. The above didn't work also :\ it installs normally as by your instructions, but it still doesn't recognize any audio devices..
- Windows 8
Hi,
Another hi-jacker here
I have just upgraded to Win 8 CP (32 bit) from Win XP (32 bit) and can't get my sound blaster x-fi xtreme audio card working...
I tried following the steps earlier in the thread but no success. I have tried the latest drivers but get the same error message as the original poster.
Is there anything you can suggest Gman?
Many thanks for any response in advance!![]()
Just realised what you asked the other posters for. Here is the info from Device Manager on my pc.
HDAUDIO\FUNC_01&VEN_1102&DEV_000A&SUBSYS_11021007&REV_1000
Regards and thanks for any help![]()
Microsoft Update Catalog
You're welcome.
You're welcome.
Hi thanks gman, downloading the latest driver from that link didnt work - the install process just gives me the same error the other guys were getting. It's ok I think I will try something else, maybe windows 7 heh.
PCI\VEN_1102&DEV_0005&SUBSYS_00331102
Could you work your magic on this card as well?
Hello and welcome. Yes, I've already checked on it and can. But before I do anything, I need to know if you're running 32 or 64 bit Windows.
If 64 bit, still can be done, but there will be hoops to jump through. I'll explain if necessary.
Ah yes of course, it's 32 bit. Thanks!
All the best
