Another thing I might point out about the UI is that many people have a desktop PC running Windows, an iPad and either an iPhone or Android phone. This sort of technology mix is very common. Microsoft has sort of jumped the gun and assumed that from day one with Windows 8, everyone is going to dump their iPads and Apple/Android phones and will move across to an all Windows environment.
That isn't going to happen, not now and most likely not for a long time. To that end, Microsoft has angered a vast number of their dedicated PC users, by inflicting on them a mobile phone interface (the lowest common denominator) unnecessarily and for really no reasonable need. The desktop UI should have been retained for the desktop, without having to resort to third party programs, and similarly for tablets (for those that want a tablet as a desktop alternative). Was this too much to ask for? Would it have really hurt Microsoft to offer such a simple option?
This is why it's called the "long haul." And still, there are cases of people dropping off their ipads elsewhere for an x86 based tablet PC.
I use a Windows Phone daily, Windows 8 daily. Why should there be two distinct UI differences if the one metro design can be adapted for each form factor rather nicely? Why should your definition of what a stale Windows system be my definition? They're both computing devices. They both run the Windows NT kernel, so why don't I have a start menu on my Windows Phone? Because it simply isn't cut out for touching. If you look at the demand for touch based devices, more people are actually buying touch AIO PCs and others are looking at the touch enabled laptops and even tablets. Why? Touch input is nicer to use than a mouse, Windows 8 can be touched better than 7. This is simply the future of computing. What a desktop will be 10 years from now won't look like what a desktop today is, or at least, HOW they'll be used. Windows 8 sparked that change. Long haul again.
And I have to speculate, if a start menu was used in Windows 8, is would fragment the overall Windows 8 UI paradigm into two different and separate UIs. This isn't like using the Windows Classis theme, this is literally one UI over another. Windows Server 2012 doesn't even do that, as again, a fleet of Windows 8 machines being managed by Windows Server 2012 would be odd to do with a start menu on Server and Start Screen on the client. And if you look at the Windows Classic theme from past Windows versions, how many people used that? How many people use that theme today? Not even a full percent I bet. So why keep that for only a small minority of users today? That's what would eventually had happened if that option was kept for two UIs, in retrospect it would had been pointless if by 10 years hypothetically, 99 percent of everyone used the default Start Screen over the menu. All it does is just postpone ripping the band aid off. Once you rip that band aid off, then you realize that hey, that wasn't too bad. I can get to all my Libraries pretty easily from Start. I can even put power tiles on it if I like. I don't like the metro apps, so I can click three times to uninstall them. Wow, what was I doing all this time saying the Start Screen was useless when I can get to point A to point B just the same, and maybe, just maybe, I actually get to what I need on the Start Screen quicker than I did with the older version.
But hey, that's just me.
- Windows 8.1 Pro
- Computer type
- PC/Desktop
- System Manufacturer/Model
- ASUS
- CPU
- AMD FX 8320
- Motherboard
- Crosshair V Formula-Z
- Memory
- 16 gig DDR3
- Graphics Card(s)
- ASUS R9 270
- Screen Resolution
- 1440x900
- Hard Drives
- 1 TB Seagate Barracuda (starting to hate Seagate)
x2 3 TB Toshibas
- PSU
- OCZ 500 watt
- Case
- A current work in progres as I'll be building the physical case myself. It shall be fantastic.
- Cooling
- Arctic Cooler with 3 heatpipes
- Keyboard
- Logitech K750 wireless solar powered keyboard
- Mouse
- Microsoft Touch Mouse
- Browser
- Internet Explorer 11
- Antivirus
- Windows Defender, but I might go back on KIS 2014
