A few hours after I started running StartIsBack I was so impressed I bought a serial key. Am now running Win8 Pro OEM installed from shop bought DVD on my top end machine and it absolutely flies!
I don't mind the bare look of the folders, etc. Quite happy to sacrifice aesthetics for speed any day. All my folders regardless of content are set to list view so only the name is visible ... no details and no navigation pane.
Aside from a few initial hiccups, like Revo Uninstaller had to be run in compatibility mode Vista or it froze when searching for left over registry entries/files ... aside from that there's no going back to Win7. Shuts down in 2 seconds flat ... unbelievable! Excel docs on Win7 took about 15 seconds to open. With W8 they open in 1 - 2 secs max. Big plus for me as I do a lot of work on Excel/Word. Intel do not support my DX58SO2 extreme board for Win8, but it runs fine with generic drivers loaded by W8. The only thing that won't run is the RaLink WiFi wireless adaptor which came with the board and also runs Blue Tooth. Work around was to buy a Blue Tooth and Wireless USB dongle. All good.
I still never use Metro, but not worried it's there. Have used it as alternative start screen just to know what it does, and can navigate it fairly quickly, but still prefer to simply have everything on the desktop ... much more efficient IMHO!
Excerpt from nsane forum:
One fact about Windows 8 is that it does have a Start Menu, but - the code for the same is hidden away.
The reason that StartIsBack is lighter on resources is the fact that it uses that very same hidden code. Hence, StartIsBack is a native Start Menu - in other words, it's the hidden Windows 8 Start Menu.
The reason why Start8 is heavier on resources is that it uses it's own extra code - not the hidden Windows 8 Start Menu code. This extra code can be seen in the form of 2 extra services that are now required to run in the background.
StartisBack vs. Start8 - Software Chat - nsane.forums
- W8 Inspiron 17R W8P+MCE HTPC
- Computer type
- PC/Desktop
- Hard Drives
- Custom HTPC systems builder, trouble shooter for Apple and PC products.
My HTPC specs:
Core i5 W7 Pro/W8 Pro+MCE
Lian Li blk mid tower 10 gigs + 2 OS HDD's W7/8.
- Other Info
- Gigabyte UD3 mobo P55 chipset.
Workstation:
Same as above but using the "M" series mobo with ATi 5670
Dell Inspiron 17R i3 3rd gen W8.
Nokia Lumia 810 W Phone8.
