Solved Refurbished HP Pavilion 17 Overheating/fan issue
As much as you may not like it then that may be your next step. Generally what you and I just discussed are good signs of either
A) a defective fan
B) a really dirty fan/inside of your case
I guess so. I'm currently not home but when I get home I'll take it apart and clean the fan.
    Windows 8.1/Windows 7
    Dell XPS 630i
    Intel Core 2 Duo E8400 3.01 GHz
    Nvidia 650i SLI
    8GB DDR2
    Dual Nvidia 8800GT 512MB SLI
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    1x Samsung 840 SSD 120GB (Windws)
    1x 500GB Hitachi 7200RPM
    1x WD Caviar Blue 1TB 7200RPM
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Very old computer. Circa 2009
    Very trusty, no hardware issues.
    Saving up for parts for a Self-Built PC.
That's tolerable, just Chrome or something on youtube? Try on youtube some flash video, it engages GPU which is in the same chip as your processor so it would work harder. Trick is to find max temperature and moment when fan speeds up.
Youtube makes it go to about 46-48C. I also found recording the screen using OBS, Makes it go to 56C.
That's still very tolerable.
Also, do you think my ram is making more heat? I have a slightly higher voltage ram that what came with the unit. (It came with DDR3L and I put DDR3 in it)
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
I don't think it's RAM, it contributes to heat only when really, really overclocked. Normally it's just about coolest part of the computer.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
The only time when you could really consider memory would be let's say if you have 32GB+ of memory and in reality only using 4-8GB max.
    windows 8.1
    iBUYPOWER
    AMD 8320
    Radeon 7850
    1024x768
    Azza Solaris
    50MBps download/10MBps upload
    Chrome/Firefox/Internet Explorer
    Malwarebytes PRO
I know but it is a higher voltage. Wouldn't that draw more power and hence cause more heat?
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
It's very small amount of power they need and that's what counts.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
It wouldn't be enough voltage to make a difference.I believe. I do know though that I have read in the past that higher voltage can shorten the life of it but again if you plan to OC a lot it should negate that I would imagine. It's sort of like this...if you have 1.5 and OC it can hurt you, if you have 1.65 and don't OC it can hurt you. Does that make sense any?
Now depending on the speed of the memory ( 1866, 1600, etc ) higher voltage may be required already. It's either 1866 or 2133 is the beginning limit for the 1.65v I forget which.
    windows 8.1
    iBUYPOWER
    AMD 8320
    Radeon 7850
    1024x768
    Azza Solaris
    Malwarebytes PRO
Not necessarily, for instance Kingston HyperX 1600 MHz works on full speed at 1.65v and on 1333 MHz at 1.5v, both are standard voltages and not considered OC.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I'm not surprised that certain brands have certain voltages for each memory actually, especially referring to Kingston as they are always bringing their A game to the field. (I especially love their 3.0 USB drives they have 2x the speed transfer of like PNY)
    windows 8.1
    iBUYPOWER
    AMD 8320
    Radeon 7850
    1024x768
    Azza Solaris
    Malwarebytes PRO
I just took my ram out.... firgured out that i had 1333MHz RAM in a 1600MHz slot. does this mean anything?
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
I have 2 x 4GB of Kingston KHX 1600 memory ( now working at 1632MHz) and they are fine but with my Kingston V300, 120 GB SSD I'm not elated with. Have couple of Kingston Traveler USB2 memories and they are not speed daemons either. Anyway, nothing of that produces any heat worth mentioning.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Only a bit lower speed, nothing critical, actual RAM controller is in the CPU and in those processors it's 1866 MHz controller.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Okay. really worried about the health of the PC, might have to take it in somewhere... dont see why the fan should be this loud, and the CPU should be this Hot.
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
That's definitely no good, they might not have put it together right.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
We'll then I guess I'll clean the fan, and maybe get a cooling pad.
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
I would take it back to Best Buy.
    HP ENVY 700-074
    Intel Core i5 4430 @ 3.00 GHz
    MS-7826 (Kaili)
    12 GB
    Nvidia GeForce GT 740
    Integrated IDT 92HD68E2 Audio
    Samsung S27C230B
    240 GB Kingston SSDNow V300 Series
    stock
    stock
    stock
    Logitech K520
    Logitech M310
    Fire Fox
    Eset Smart Security 7
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    HP ENVY 700-074
    MS-7826 (Kaili)
    12 GB
    Samsung S27C230B
    stock
    stock
    stock
    Logitech K520
    Logitech M310
    Fire Fox
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
Do you have an email or credit card statement?
    HP ENVY 700-074
    MS-7826 (Kaili)
    12 GB
    Samsung S27C230B
    stock
    stock
    stock
    Logitech K520
    Logitech M310
    Fire Fox
