David Bailey
Banned
- Location
- Harrisonburg, Va.
I thought it already has .exe hidden after whatever you name it since known extension types are hidden?
I can not have a space in the file name if used with a batch file?
I removed the space and it works, BUT, what's the point this does not remove the prompt it just switches the additional action from a click verification to a key. I wish for it to empty in a single click just like things are deleted with a single press of the delete button; no confirmation (if you have it disabled). If there is a way to remove the "press any key to continue" that is what I am after as long as I don't have to close out the command prompt after.
Don't worry about the space in the exe file.
Having no spaces is good.
Just rename the shortcut.
Spaces don't matter there.
To make the command window simply disappear with no further pressing of a key, remove the "pause" line.
Change:
EmptyRecycleBin.exe /Q
pause
To:
The window will close automatically.
- Windows 8.1.1 Pro with Media Center
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Gateway
- CPU
- AMD K140 Cores 2 Threads 2 Name AMD K140 Package Socket FT1 BGA Technology 40nm
- Motherboard
- Manufacturer Gateway Model SX2110G (P0)
- Memory
- Type DDR3 Size 8192 MBytes DRAM Frequency 532.3 MHz
- Graphics Card(s)
- ATI AMD Radeon HD 7310 Graphics
- Sound Card
- AMD High Definition Audio Device Realtek High Definition Audio USB Audio Device
- Monitor(s) Displays
- Name 1950W on AMD Radeon HD 7310 Graphics Current Resolution 1366x768 pixels Work Resolution 1366x76
- Screen Resolution
- Current Resolution 1366x768 pixels Work Resolution 1366x768 pixels
- Hard Drives
- AMD K140
Cores 2
Threads 2
Name AMD K140
Technology 40nm
Family F
Extended Family 14
Model 2
Extended Model 2
Stepping 0
Revision ON-C0
Instruction
- Browser
- Opera 24.0
- Antivirus
- Avast Internet Security
