Help with minidump ntoskrnl.exe problem
Stereoscopic 3D USB controller driver from nvidia caused the crash.
Yes, I saw this, but what dou you thing? Is this real reason of crash? I am with the latest driver from NVIDIA. May be this is the reason? ;) New driver, old game - Assassin Creed Black flag on 3d Stereoscopic.
    AMD FX(tm)-4300 Quad Core
    GIGABYTE 990FXA-UD3 rev.4
    8GB
    GIGABYTE NVIDIA GTX 650
Somwhere I saw that RAM could be problem in this kind of BSOD. I tested my memory all nigh with memtest86. No errors. But I am not sure what kind of test have to select in memstes and did i choose the right one.
    8GB
Disable Stereoscopic 3D USB controller driver and see if it helps. As for RAM, you've tested it. I gave you the instructions on how to do it.
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
Hi again,
Unfortunately today I received unexpected power off again. No shut down - directly system went off. After more than 14 days. In the Event view I saw just this:
"The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
-System
-Provider
Name]
Microsoft-Windows-Kernel-Power
Guid]
{331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID41
Version3
Level1
Task63
Opcode0
Keywords0x8000000000000002
-TimeCreated
SystemTime]
2015-02-01T00:52:49.362970000Z
EventRecordID5225
Correlation
-Execution
ProcessID]
4
ThreadID]
8
ChannelSystem
Computerbogo-PC
-Security
UserID]
S-1-5-18
-EventData
BugcheckCode0
BugcheckParameter10x0
BugcheckParameter20x0
BugcheckParameter30x0
BugcheckParameter40x0
SleepInProgress0
PowerButtonTimestamp0
BootAppStatus0
and this
The previous system shutdown at 2:50:10 AM on
‎2/‎1/‎2015 was unexpected.
+System
-Provider
Name]
EventLog
-EventID6008
Qualifiers]
32768
Level2
Task0
-TimeCreated
SystemTime]
2015-02-01T00:53:04.000000000Z
EventRecordID5216
ChannelSystem
Computerbogo-PC
Security
-EventData
2:50:10
AM
‎2/‎1/‎2015
235594
DF07020000000100020032000A003E01DF07020000000100000032000A003E013C0000003C0000000000000000000000000000000000000001000000FEFFFFFF
Binary data:
In Words
0000: 000207DF 00010000 00320002 013E000A
0010: 000207DF 00010000 00320000 013E000A
0020: 0000003C 0000003C
00000000 00000000
0030: 00000000 00000000 00000001 FFFFFFFE
In Bytes
0000: DF 07 02 00 00 00 01 00
ß.......
0008: 02 00 32 00 0A 00 3E 01 ..2...>.
0010: DF 07 02 00 00
00 01 00 ß.......
0018: 00 00 32 00 0A 00 3E 01 ..2...>.
0020: 3C
00 00 00 3C 00 00 00 <...<...
0028: 00 00 00 00 00 00 00 00
0030: 00 00 00 00 00 00 00 00 ........
0038: 01 00 00 00 FE FF
FF FF ....þÿÿÿ
It is very annoying. How to find out what is the problem? It very rare to find what is happening. But I have guaranty of all of my components and I'd like to solve this or replace damaged hardware if there is one.
Please, give me advice.
    8GB
What's the age, model and wattage of your PSU?
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Fortron - 500W - have to open the case to see. I bought it before two years. This is the only one old component of mine with no quaranty. I tested with other PSU - from my friend - there were unexpected shut downs again. I gave my PSU to other friend of mine to check its voltage and he told me everything was ok on the first sight.
    8GB
The PSU of my friend is 550 W - Huntkey. I thing it is enough power for my PC. I did not calculate, but may be have to. I have to tell you that - when I bought my new components - there was an year without any problems.
    8GB
Is your PC clean of dust? What are the temperatures like?
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Yes, I cleaned several times when the problem started. I checked permanently the temperature. No problem. Honestly, after power off - today - I turned on the PC and heart that the CPU cooler was working it 100 percent. After went slowly. But I noticed that before - when there was not lost of power. May be in the beginning of starting system do that normally.
    8GB
What do you suggest?
    8GB
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
I am testing now with Prime 95 - blend test. I saw somewhere that I have to test about 48 hours. Is this true?
And what do you think: Have I preinstall Windows? My windows Is new installed. I installed it clearly because I had trouble with unexpected shut downs.
    8GB
Oh, you did reinstall windows in the meantime? OK then. Run it 24h.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
No, just before to write here.
    8GB
I am looking now that my CPU has temperature between 60-70 C. I am using Easy Tune 6 and HWMonitor. And what is normal RPM for AMD FX 4300 fan? Mine is 404 RPM now.
    8GB
I restarted and fan has 2200 RPM, CPU temperature is 30 C. Why this fan works slowly sometimes? May be cool an quet option not work correctly.
    8GB
Hmmm - now running blend test and rpm increase to 2700 rpm. Before restart it not worked. It was 404 RPM. Strange. Is it possible to be my problem. May be the BIOS shut s down the PC when CPU goes overheated. Have to see how it is configured to shuts down. And how to find out why this could be defected? Or there is a software that have to command it?
    8GB
It could be that your fans were in idle mode and when you started something that put load on your system they reacted inappropriately, Have you changed thermal paste recently? I wouldn't be worried if everything is working as it should now. As for fan speeds you can easily set them up in BIOS.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Yes, I replaced thermal paste soon. When I cleaned my PC. The CPU is perfect= When is no processes - 28C. Form 12 hour running blend test and has 50 C, fan is 3000 RPM. But before restart yesterday was 400 rpm and 70 C.
When test finish have to see bios settings for fans. May have to disable Cool and Quiet option?
    8GB
You can try. Also:
- open Event Viewer (run eventvwr.msc from the "Run" dialog))
- expand the Custom Views category (left click on the > next to the words "Custom Views")
- right click on Administrative Events
- select "Save all Events in Custom View as..."
- save the file as Admin.evtx
- zip up the file (right click on it, select "Send to", select "Compressed (zipped) folder")
- upload it with your next post (if it's too big, then upload it to a free file-hosting service and post a link here).
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
