Give this a try. The file was created by
kronckew, one of our colleagues. Tested it on my Laptop, and it worked!
Boot to
Safe Mode.
Go to Start > All Programs > Accessories >
Command Prompt
Right-click the
Command Prompt, and select:
Run as Administrator
At the
Command Prompt, copy/paste (with the mouse) the following text inside the code box below, and press:
Enter
@echo off
rem delete old files
del /q %windir%\logs\cbs\cbs.log
del /q c:\sfcdetails.txt
rem run sfc
sfc /scannow
rem filter out non essential junk from the cbs.log
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >c:\sfcdetails.txt
rem open details in notepad
notepad c:\sfcdetails.txt
rem optional command to shut down & restart pc after running. this may be needed if
rem sfc replaces some critical files. uncomment (remove the 'rem') to activate.
rem shutdown -r
exit
When sfc is done, a file named
sfcdetails.txt appears.
Please save the
sfcdetails.txt file to the Desktop, and post it in your reply.
To run the program a second time, open the
Command Prompt, right-click and select:
This time, type in the following:
sfc /scannow
Press: Enter
When done, a file named
sfcdetails.txt appears once again.
Please save the file to the Desktop, as
sfcdetails2.txt, and post it in your reply.
