Ok, so I've had W8 RP installed since it's second day of availability, and so far I've had zero problems; until now.
Upon restarting my VAIO, it shows the Windows screen that it shows after you install the RP, it's the loading screen before you choose which OS you want to boot. This screen is now last for probably 5 minutes, and then my screen turns completely off, and then it turns on, but is still completely black, and then it says something like "Automatic repair of drive (D (which is my current W7 drive) and then it, after about 8 total minutes, goes to where you can choose which OS to boot. If I choose 8, everything is fine; if I choose 7, different story. I choose 7, then it gives me the option of Launch automatic repair (recommended) and Start Windows normally. If I choose repair, it shows the background of the auto repair screen, and the mouse appears, but nothing else happens. If I choose Start Windows normally, it shows the W7 loading screen for about 10 seconds, then it goes back to the loading screen before you choose an OS.
Oh, and what makes it better, is if I'm in 8, and I try to explore, view properties of, or basically anything else dealing with the W7 drive, Windows Explorer (and eventually the Desktop) becomes completely unresponsive, resulting in me having to sign out and back into my PC.
Please, please, PLEASE HELP.
- Windows 8 Release Preview
- System Manufacturer/Model
- Sony VAIO
- CPU
- Intel Core i3
- Memory
- 4GB
