BSOD Problems after upgrading to clean install of W8
mrrevesz
Hello,
I recently upgraded to windows 8 on my gaming desktop. As such, started the blue screens. Attached are the dump logs. The blue screens happens randomly either under load or just idle.
  • minidump.zip
    Windows 8 Pro x64
Sorry for the delay in responding. There just aren't that many people who do BSOD analysis, so at times we get a bit overwhelmed!
I do not recommend using wireless USB network devices. Especially in Win7/Win8 systems.
These wireless USB devices have many issues with Win7(and I suspect with Win8) - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7/Win8 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
10 Nov 2012 - I'm seeing an upswing in SSD errors - but most appear due to older storage controller drivers. I strongly suggest NOT using storage controller drivers that don't date from 2012 (if none are available, don't connect an SSD to that controller)
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: https://www.eightforums.com/bsod-cr...-pc-reboots-when-waking-sleep.html#post169956
This device is having problems:
Prolific USB-to-Serial Comm Port (COM3) USB\VID_067B&PID_2303\6&1E58491E&0&3 This device cannot start
Please uninstall the software for the device and physically remove the device from the system.
If the device is needed, please ensure that you get the latest, Win8 compatible drivers for it.
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
ae1000w7.sys Tue Jun 7 22:40:42 2011 (4DEEE12A)
Linksys AE1000 High-Performance Wireless-N Adapter
http://www.carrona.org/drivers/driver.php?id=ae1000w7.sys
ALSysIO64.sys Sat Jul 9 20:27:45 2011 (4E18F201)
Core Temp - CPU temperature monitor
http://www.carrona.org/drivers/driver.php?id=ALSysIO64.sys
Rt630x64.sys Wed Oct 19 08:12:55 2011 (4E9EBEC7)
Realtek PCI/PCIe Adapters
AODDriver2.sys Tue Apr 17 22:19:31 2012 (4F8E24B3)
AMD Overdrive; also in EasyTune6 for Gigabyte motherboard [br] Known BSOD issues in Win7
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
Analysis:
[font=lucida console]**************************Fri Jan  4 21:43:57.274 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010413-7659-01.dmp]
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]0 days 0:10:30.930[/B]
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
BugCheck [B]101, {31, 0, fffff88002acf180, 3}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000101]CLOCK_WATCHDOG_TIMEOUT (101)[/url]
Arguments:
Arg1: 0000000000000031, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: fffff88002acf180, The PRCB address of the hung processor.
Arg4: 0000000000000003, 0.
BUGCHECK_STR:  CLOCK_WATCHDOG_TIMEOUT_4_PROC
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]CLOCK_WATCHDOG_TIMEOUT_4_PROC_ANALYSIS_INCONCLUSIVE[/B]
  BIOS Version                  F6
  BIOS Release Date             03/30/2012
  Manufacturer                  Gigabyte Technology Co., Ltd.
  Product Name                  GA-990FXA-UD3
**************************Fri Jan  4 21:32:55.217 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010413-7129-01.dmp]
System Uptime:[B]0 days 0:00:07.873[/B]
Probably caused by :[B]memory_corruption ( nt!MiFinishHardFault+5ec )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff80071a77cbc, 0, ffffffffffffffff}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001E]KMODE_EXCEPTION_NOT_HANDLED (1e)[/url]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80071a77cbc, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_R
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]0x1E_c0000005_R_nt!MiFinishHardFault[/B]
  BIOS Version                  F6
**************************Fri Jan  4 19:09:56.371 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010413-6801-01.dmp]
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010413-7332-01.dmp]
System Uptime:[B]0 days 0:09:29.027[/B]
*** WARNING: Unable to verify timestamp for amdppm.sys
*** ERROR: Module load completed but symbols could not be loaded for amdppm.sys
BugCheck [B]101, {31, 0, fffff88002c5d180, 2}[/B]
Arguments:
Arg3: fffff88002c5d180, The PRCB address of the hung processor.
Arg4: 0000000000000002, 0.
PROCESS_NAME: [B]System[/B]
  BIOS Version                  F6
**************************Thu Jan  3 03:03:22.484 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010313-8346-01.dmp]
System Uptime:[B]0 days 0:02:41.160[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!IopCreateFile+e1 )[/B]
BugCheck [B]3B, {c0000005, fffff80346871bc1, fffff88010a850a0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80346871bc1, Address of the instruction which caused the bugcheck
Arg3: fffff88010a850a0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]ipoint.exe[/B]
FAILURE_BUCKET_ID: [B]0x3B_nt!IopCreateFile[/B]
  BIOS Version                  F6
**************************Thu Jan  3 03:00:13.870 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010313-7332-01.dmp]
System Uptime:[B]0 days 0:00:41.546[/B]
Probably caused by :[B]hardware ( dxgmms1!VidSchiWaitForSchedulerEvents+23c )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff880075b8a78, fffff8800a084908, fffff8800a084140}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x1000007E]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/url]
Arguments:
Arg2: fffff880075b8a78, The address that the exception occurred at
Arg3: fffff8800a084908, Exception Record Address
Arg4: fffff8800a084140, Context Record Address
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]IP_MISALIGNED_dxgmms1.sys[/B]
**************************Thu Jan  3 02:58:26.464 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010213-7207-01.dmp]
System Uptime:[B]0 days 0:01:12.140[/B]
Probably caused by :[B]memory_corruption ( nt!MiAgeWorkingSet+241 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80188d1c7a0, fffff88002f63768, fffff88002f62fa0}[/B]
Arguments:
Arg2: fffff80188d1c7a0, The address that the exception occurred at
Arg3: fffff88002f63768, Exception Record Address
Arg4: fffff88002f62fa0, Context Record Address
PROCESS_NAME: [B]MsMpEng.exe[/B]
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nt!MiAgeWorkingSet[/B]
  BIOS Version                  F6
**************************Thu Jan  3 02:55:22.443 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010213-7722-01.dmp]
System Uptime:[B]0 days 0:09:04.119[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ObReferenceObjectByHandleWithTag+262 )[/B]
BugCheck [B]3B, {c0000005, fffff802b6049a42, fffff8800e933000, 0}[/B]
Arguments:
Arg2: fffff802b6049a42, Address of the instruction which caused the bugcheck
Arg3: fffff8800e933000, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]0x3B_nt!ObReferenceObjectByHandleWithTag[/B]
  BIOS Version                  F6
[/font]
3rd Party Drivers:
[COLOR=RED][B]ae1000w7.sys                Tue Jun  7 22:40:42 2011 (4DEEE12A)[/B][/COLOR]
[COLOR=RED][B]ALSysIO64.sys               Sat Jul  9 20:27:45 2011 (4E18F201)[/B][/COLOR]
[COLOR=RED][B]Rt630x64.sys                Wed Oct 19 08:12:55 2011 (4E9EBEC7)[/B][/COLOR]
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
dump_storahci.sys           Wed Jul 25 22:30:35 2012 (5010ABCB)
RDPUDD.dll                  Fri Oct 12 01:50:01 2012 (5077AF89)
nvlddmkm.sys                Fri Nov 30 22:24:02 2012 (50B97852)
[COLOR=RED][B]AODDriver2.sys              Tue Apr 17 22:19:31 2012 (4F8E24B3)[/B][/COLOR]
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
[/font]
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
RDPUDD.dll - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
