Hyper-V Remote File Browser Shortcut - Create
How to Create a Hyper-V "Remote File Browser" Shortcut in Windows 8 and 8.1
Hyper-V Remote File Browsing is a shell namespace extension implemented by Hyper-V that provides a way to browse the folders/files on a remote Hyper-V server without requiring the server to open an extra shell over the network you are managing. The benefit of the "Remote File Browsing" is you don't have to use the normal network share to access any location on that Hyper-V server. If you want to create a new folder, you may need to add the folder name at the end of the export path.
This tutorial will show how to create or download a "Hyper-V Remote File Browser" shortcut in Windows 8.
EXAMPLE: Hyper-V "Remote File Browser" in Windows 8
To Download a "Hyper-V Remote File Browser" Shortcut
Hyper-V_Remote_File_Browser_Shortcut.zip
2. Save the .zip file to the desktop.​
3. Open the .zip file and extract (drag and drop) the Hyper-V Remote File Browser shortcut to the desktop.​
4. Unblock the extracted Hyper-V Remote File Browser shortcut.​
6. When finished, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.​
To Manually Create a "Hyper-V Remote File Browser" Shortcut
%windir%\explorer.exe shell:::{0907616E-F5E6-48D8-9D61-A91C3D28106D}
3. Type Hyper-V Remote File Browser for the name, and click/tap on the Finish button. (see screenshot below)​
4. Right click or press and hold on the new Hyper-V Remote File Browser shortcut, and click/tap on Properties.​
6. In the line under "Look for icons in this file", copy and paste the location below and press Enter. (see screenshot below)​
RemoteFileBrowse.dll
  • Hyper-V_Remote_File_Browser_Shortcut.zip
I am wondering what this actually does... Can anyone help me here? :huh:
    Windows 8 Pro x64
    DIY
    Intel i5-3570
    Asus P8Z77-V deluxe
    Corsair Vengeance DDR3,1600-16GB KIT
    Sapphire AMD Radeon HD7870 FLEX GHZ PCI-E
    On-board
    2x Eizo S2410W
    2x 1920x1200
    Samsung 840 series Pro 256GB
    2x Western Digital Green 3TB - 3.5inch
    Corsair HX 650W
    Define R4 Arctic White
    Mugen 3 PC Games Edition
    Microsoft Wireless 6000
    IE 10, of course
Hello Guiri,
I've added some more information at the top of the tutorial to help with what Hyper-V Remote File Browsing is for. :)
Thanks for the addition but I'm afraid I still only get what you showed in your first screen shot:
In other words: an empty screen.
I just started experimenting with Hyper-V so maybe I'll find out anyway. ;)
Off-topic: I noticed that the CPU frequency displayed in Task Manager stays fixed as soon as Virtualization is enabled in the BIOS and it no longer changes depending on the load. If I set Virtualization at disabled, the frequency starts changing again but then I cannot start VMs. Found some posts online back from September reporting this, strange it's still not fixed...
    Windows 8 Pro x64
    DIY
    Intel i5-3570
    Asus P8Z77-V deluxe
    On-board
    2x Eizo S2410W
    2x 1920x1200
    Corsair HX 650W
    IE 10, of course
Yeah, you'll have to set up the folders to be in it. I haven't done it myself, so I'm not sure on the specifics on how. I just created this shortcut for those that already have it setup.
Here's a couple of links below for more info about it.
Using Constrained Delegation to remotely manage a server running Hyper-V that uses CIFS/SMB file shares - Jose Barreto's Blog - Site Home - TechNet Blogs
Part 1 - Hyper-V Remote Management: You do not have the required permission to complete this task. Contact the administrator of the authorization policy for the computer
I am confused with this one, it seems to just open My Documents folder for the local computer.
    Windows 7 , 8 , OpenSuse12.1, Ubuntu 12.04, Fedora
    HP
    AMD Turion
    HP
    8gb
    ATI, AMD
Hello S3curityPlu5,
You would need to have Hyper-V (available in Windows 8 Pro and Enterprise only) turned on in Windows Features before you will see the "Remote File Browser" window.
Hope this helps, :)
Hello Brink,
Thanks a lot for this tutorial! How do i actually put folders in this box? I realize you haven't done this before but do you know where I can look for more information? I have looked through the web and no one seems to have an answer, the two websites that you posted don't seem to have the answer either. The server I am running is a Hyper-V core server 2012 and the client is Windows 7 or Windows 8. To make it even more strange when I go to ::{0907616E-F5E6-48D8-9D61-A91C3D28106D}\HYPERV-SERVER\D: it says invalid path but that is the path that is used when going to the "Browse" button on the new virtual machine wizard... What am I missing?
Thanks in advance!
    Windows 7
Hello Kevvy, and welcome to Eight Forums.
I don't have anything to test with for this, but I'll do some digging to see what else I can find that may help and post back. :)
Oh I have Hyper-V turned on and I also have several Virtual Machines running all the time on Hyper-V but when I open this shortcut it still just opens My documents folder from my logged on user account. I have not yet had time to look into this, as I just noticed the email that told me someone responded to this so that's why I thought to come back here. Now I will go investigate further, but I definitely have Hyper-V turned on and running at all times. I use it for SharePoint, System Center Configuration Manager and for a Windows 8.1 preview VM.
    HP
    AMD Turion
    HP
    8gb
    ATI, AMD
