Wireless adapter is "Enabled" but not working
dadili
I plugged in Alfa AWUS036H adapter and Win 8.1 found drivers and installed it. But It is not working.
Below you can see how it looks and my Device Manager. It just says it is "Enabled" and that's it.
It already happened on Win 7 and I had to reinstall windows, but I wouldn't like to do it here
    Win 8.1
Why do you keep installing them over and over, it is obvious that the Realtek is online, with great signal strength. You don't say what kind of device you are using or what you are trying to do with multiple wifi adapters. Do you have multiple routers, a G and a dual band? I'm not sure if you are a person or a poorly written bot program at this point...guess I should call a psychic...:zip:
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
I'm not installing them over and over.
This external wireless device has antenna and I want to use it.
I'm real human being made of flesh and bones.
Please don't be rude.
    Win 8.1
Try disabling all other WiFi connections, windows let you use only one at a time to connect to internet.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
That's not it. I managed to have multiple adapters enabled and they worked
Adapter enabled and actually connected to internet are two different things.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
