mrillusion
Ok so i am trying to install windows 8 X64 onto a different hard drive as windows 7 so i can switch between the two at startup.Ok so my problems started yesterday when trying to install windows 8 onto the Hard Drive i was getting"Windows cannot be installed to this disk. The selected disk has an MBR partition table. On EFI systems, Windows can only be installed to GPT disks."To fix this i converted the disk to a GPT disk in Disk ManagerNow im getting the Error "Setup was unable to create a new system partition or locate an existing system partition. See the setup log files for more Information."And i have no idea how to get around the problem. Here is a screenshot of disk manager at the moment.
I am trying to install Windows 8 to Disk 2All help is appreciated.Thank you in advance.
P.s if i missed any info you need just ask
- Windows 7 64bit
- CPU
- Intel I5 2500K
- Motherboard
- Asrock Extreme 3 Gen 3
- Memory
- G Skill 8GB
- Graphics Card(s)
- Sapphire 6950
- Screen Resolution
- 1980x1080
- Hard Drives
1x Crucial 128GB SSD
1x Seagate Barracuda 3.5in
1x Seagate Barracuda 2.5in
- PSU
- Corsair AX750
- Case
- Cooler Master HAF X
- Cooling
- 6 Fans...
- Keyboard
- Logitech K200 $9 keyboard
- Mouse
- Old Logitech Wireless
