win8 and harddisk problem
kvint3
2
Hello everybody.
I have installed my new Win8 and it seems it is in conflict with my second harddrive - WDC WD3200AAKB-00WHA0.
When the drive is plugged in, Win8 won't start at all, when I remove it, Win8 boots normally (from my first harddrive).
BIOS settings are correct, the first booting device is the first harddrive, where win8 is installed.
All HDDs are SATA.
Please, do you have any comments, any ideas?
Thank you very much!
Kvint3
    win8
znod
2,156
What happens if you plug it in after restarting? If lucky, then you could get control of it, maybe.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
znod
2,156
That' too bad. Check out the WD Lifeguard Tools manual here. Might get you going. There is a link on the 4th intro page of the manual that apparently will take you to more specific info about your drive.
    EVGA 570 SC
    Gateway
    Dual Boot:
