Wifi is unstable, yet ethernet cable is top speed?
Cabinet
2
Hey guys!
This issue is most puzzling to me.
Since yesterday the internet began to act unsoundly (through WiFi). As in I never had this problem before. There were periods where it was fast enough to play some online games, watch Youtube no problem, and then it would shut off randomly. So since yesterday I have been restarting the modem with only very short term resolutions to the issue.
I accessed the modem through my web browser and it says the connection is always working fine. Despite that, I called my ISP and they claimed there was an issue, and forwarded it to Deutsche Telekom. Since then I did some experimenting and plugged my computer into the modem with the ethernet cable.
Boom. No problem whatsoever. It's been top speed and reliable.
So I'm assuming this is an issue with Windows 8, hopefully you guys can help me out!
If it helps, I downloaded and installed updates for Windows today. There are 18 optional ones that I did not download yet, but I did download and install the important ones no problem. I checked the network adapters and they all state "The best driver for your software is already installed."
Thanks in advance.
    Windows 8 64 bit
Mr Sardonicus
Chicago IL, USA
203
You may want to go to the website of the laptop's manufacturer and download the latest driver, and install it. Using the OEM driver, sometimes eliminates the problem.
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNT
    Sapphire ATI Radeon R7 250
    Realtek ALC892
    Samsung UN32EH5000, Dell 1703FPT
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Samsung 128 GB 840 PRO
    SeaSonic M12II SS-500GM
    Fractal Design Define R4
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Bose Companion 2 Multimedia Speakers
Hey guys!
Thanks in advance.
You really should install inSSIDer WiFi scanner to check the wireless landscape in your area. Channel overlap is a common problem in most area's, inSSIDer allows you to choose the best possible channel based on what inSSIDer shows in your area.
Click where it says "direct download link".
inSSIDer - Free download and software reviews - CNET Download.com
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
