Does your modem/router have QOS toggled on?
Which router are you using?
I'm guessing it's actually a configuration issue at your routers end and not Win 8.
I don't know what router im using
and idk what QOS is D:
But also i don't think its my router's issue but idk. Windows 7 laptop worked fine with this router. But windows 8 doesn't seem to be wanting to work with me D:
QOS is Quality Of Service i think.
Sir,
you see we try to help you, your kind and everythig, but:
you keep saying that you do not think it's your router's issue
but we think **it can be in fact**
it can as well be: *that* router is not compatible with *that* PC, which one is faulty?
I would do this:
1) verify that wireless access is encrypted
2) reset all the settings you talk about in the first thread post, unless you knew what you where doing of course;
3) perform a speedtest.net with win8(wire&wireless), also with another wireless device(if you have) both from the same position and compare results
4) remove all the "bloatware/crapware" from your PC, you can as well remove the trial antivirus as suggested in
a post above, windows 8 has a built in antivirus (Defender) that shoud be ok, unless you know that you need
something more/different of course;
ultimately, if you do not know what router you are using you may not have access to it or you are a bit lazy
hope this helps,
Roy.
