wifi Adapters issues
MJ1
5
Hello Guys ,
I have Asus K550L Laptop
Working on Windows 8.1
my issue is that i installed more than wifi adapter during last few months to try which of them works better for me and stuff...
well i finally decided that ALFA AWUS036NHV is the one i want to use as my wifi adapter so i installed it and started working on it but i get many connection hiccups and issues.
and i been recommended to disable , deactivate and delete all the old wifi adapters
and also disable the wifi adapter that built in the laptop and to get my new adapter to work successfully.
the problem is i really don't know much about this stuff so i actually don't know which are the old ones that needed to be deleted and how to do so..
so can you please guide me to disable all the old stuff and reinstall my new adapter?
Regards
    ASUS / K550L
    Intel Core i7-4500 @ 1.80GHz 2.40GHz
    6144 MB RAM
DMHolt57
Austin, Texas
1,591
Go in Network and Sharing, click on Change Adapter Settings on left side, right click on an adapter not being used and select disable, it should then appear with a red X. When only the adapter you want to use is active and enabled, do you have good signal strength, does it drop connections, can you see other connections available?
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
Ztruker
Also look in Device Manager, Network Adapters. Click on View, Show hidden files too.
Any that are dimmed (not connected), right click and Uninstall.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
