Websites don't always fully load!
bobcree
17
I am using Windows 8. Often a web page will not fully load and I have use "refresh" one or more times to get it to load. Is there something I am doing wrong or a setting I can change?
Thanks,
Bob
    Tablet
    Dell
andyparks
wombwell uk
89
Are you using windows 8.1 or windows 8
    acer ax3950
    i3 530
    4 gig ddr 3
    dont need one as i go on onlive cloud gaming
    none
    i-inc 19 inch wide
    640 gig
    fan
    logitec s540
    motor mouse
    60 meg virgin media uk
Maybe empty your temporary internet files for your browser ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
torre
375
According to your specs, you are on a Dell tablet, correct ?
Have you checked the Dell website or googled possible solutions for a tablet ?
    Win 8.1 64bit
    Toshiba
    Intel i3, 2348
    4GB
    Intel HD3000
bobcree
17
Not on Tablet but on laptop
I am using a Dell laptop with windows 8. Have had the laptop for a few months. Some web sites work fine and others will not fully load until I use the refresh command a few times.
    Tablet
    Dell
torre
375
#8
Forgot to ask about your AV. Have you temp disabled the AV to see if there is a difference ?
Did you system come with Win8 or when did you upgrade ?
    Win 8.1 64bit
    Toshiba
    Intel i3, 2348
    4GB
    Intel HD3000
bobcree
17
#9
My laptop came with Windows 8. I am not planning to upgrade to 8.1 for a while.
    Tablet
    Dell
