Solved Vision Engine Missing Everything
48
Almost every option in vision engine is gone. I can't manage my lcds etc or use hydravision. All of the stuff that is normally in vision engine is just not there anymore. I have had this issue since I loaded 8. I did get the display driver in and .net3.5 but there is nothing in vision engine no matter what version I instal.
Is this normal? I don't understand why it runs but lacks all options.
    Win7 Ultimate x64 SP1
    Custom Build (What Else Would It Be?)
    AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz
    Gigabyte GA-890FXA-UD5
    CORSAIR DOMINATOR GT 8GB (2 x 4GB) 1866 DDR3
    XFX HD-697A-CNDC Radeon HD6970 2GB 256-bit
    Creative SoundBlaster X-Fi Platinum Fatal1ty Edition
    Dual 25 Inch Hanns-G HZ251
    3840x1080 (1920x1080 x2)
    Corsair 850W Single Rail
    Thermaltake V9 BlacX w/ Dual HDD Docking Station
    Air/Copper
    Kensington (Low-Profile)
    Creative Fatal1ty
    Cable 15Gbit (15 Down 5 Up)
    XIGMATEK HDT-S1284F 120mm HYPRO Bearing CPU Cooler, LG Blu-Ray Burner.
