Solved USB Device not recognised
sparkleshateyou
Hello,
Recently my "PS to PC Converter" USB device, as shown in image was not recognized by my laptop. It was working fine as of yesterday, where I was playing FIFA with my friend. Then today when I plug it in, it says USB device not recognized even though I can still on the analog but the controller is not detected by the game. Other games that I use to play with controllers are also not detecting the device. I kept reinstalling the driver but still the same message. Restarting computer, turning it off for a few minutes did not solve my problem too. I'm pretty sure my USB ports are fine as my mouse, keyboard and hard drives are working in all of the USB ports.
Need help here, will buying another one will solve the issue or my laptop got problem?
EDIT: I check the Device Manager and found a yellow exclamation mark on Other Devices named "Unknown device", I check the properties and says Code 43 on the status. I Enable/Disable it, still the same message.
    ASUS
    Intel(R) Core(TM) i7-4500U CPU @1.80 GHz 2.40 GHz
    4.00 GB (3.89 GB usable)
    GeForce GT 740M
    Realtek High Definition Audio
    Generic PnP Monitor
    1366x768 (60Hz)
    OS (C:) 372 GB
    Data (D:) 537 GB
    Razer BlackWidow Ultimate 2014
    Razer DeathAdder Black Edition
    1.5 Mbps
    Windows 8.1 Pro with Media Center x64
    Custom
    Intel Core i7-3820 CPU OC @ 3.80GHz
    Gigabyte G1.Assassin2
    Corsair Dominator 16GB Quad Channel DDR3
    Nvidia by EVGA - GeForce GTX 670 4GB
    On board Creative SB X-Fi
    acer 24" H243H
    1920 X 1080
    Main 500GB Hybrid Drive @ 7,200RPM
    Secondary OCZ SSD Vertex 3 Max IOPS
    Silent Pro 1000w gold 80+
    Azza Hurrican 2000
    Liquid CPU cooler & fans
    Microsoft Comfort Curve 2000
    Tek Republic Wired Laser Mouse
    5ms Ping 5.15Mb/s Download .64Mb/s Upload
    Internet Explorer
    Defender, Malwarebytes
Didn't work. Still the same. I want the device to be installed like the first time it is being plugged in.
For example, like this..
    ASUS
    GeForce GT 740M
    Generic PnP Monitor
    1366x768 (60Hz)
    OS (C:) 372 GB
    Data (D:) 537 GB
    1.5 Mbps
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
If the system restore did not work (as suggested by DustSailor) and you have done nothing else of major significance to you rig (since yesterday), there is a strong possibility that your PS-to-PC Converter just went bad. However, there is no way to actually confirm that from afar. So, can you try it on a friend's PC to see if it might work elsewhere? If not, you may have to just take a chance on buying a new one. Good luck with your decision from here.
my2cents
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
System Manufacturer : ASUSTeK COMPUTER INC.
System Model : S551LB
BIOS : S551LB.207
Is that information enough?
Yeah I'm gonna try it on my sister's laptop later this evening, will report back.
    ASUS
    GeForce GT 740M
    Generic PnP Monitor
    1366x768 (60Hz)
    OS (C:) 372 GB
    Data (D:) 537 GB
    1.5 Mbps
Yes, hopefully that will help prove where the problem lies.
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
I was going to suggest reinstalling, or rather installing the newest driver for the chipset. It can't hurt, and worth a try if it does end up working on her computer. My theory would be something changed on your computer, but it could be that the cable went bad. It just doesn't happen often, that I've encountered.
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
I think this is solved. The "PS to PC Converter" usb cable was the issue, the same message appears on 2 of my sister's laptop. Buying another one then.
    ASUS
    GeForce GT 740M
    Generic PnP Monitor
    1366x768 (60Hz)
    OS (C:) 372 GB
    Data (D:) 537 GB
    1.5 Mbps
I've been wrong before
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
Glad you were able to isolate your issue and glad we could help you in the process.
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Yup, thanks for the help guys, appreciate it!
    ASUS
    GeForce GT 740M
    Generic PnP Monitor
    1366x768 (60Hz)
    OS (C:) 372 GB
    Data (D:) 537 GB
    1.5 Mbps
