Hey.
I've just come across an error which is quite frustrating. I use a Sandisk Cruzer Extreme USB 3.0 32gb flash drive. When I plug the flash drive in, autoplay does not come up however the flash drive shows up on My Computer, but not Device Manager. It does not show up on the tray (the "Safely Remove Hardware" icon), but other USB flash drives do. The drive is fully working and I can transfer files to and from the drive, I just cannot autoplay nor eject the drive safely.
I've done the obvious such as ensuring autoplay is enabled, formatting the drive, trying different ports, and now I'm not sure what the problem can be.
I've observed that it's only the first USB port on the front panel that has this problem, but all other USB drives autoplay fine on this port. (I think only usb 2.0 - 3.0 devices do not autplay)
Any help would be good, cheers.
