Previously i had installed windows 10 and 2 days ago i decided to revert back to windows 8.1. I followed the steps as mentioned in this site How To Remove Windows 10 Technical Preview - LoveMySurfaceLoveMySurface. now it says 'unable to reset pc.a required drive partition is missing'.
I used command prompt and disk partition , it says there is no partition to show. Is there any thing i can do.
help needed, thanks!
