The problem with System Restore,context menu and Refresh
machonis
Hi,
This is my first post on the forum. I am of Polish so I apologize in advance for my language errors. Translator, translate the text: p
I have this system of seven months, and already appeared first troubling issues with which I tried to deal with, but unfortunately did not bring any positive effects.
One day after the installation of the drivers your computer does not want to run for a few seconds and showed a blue screen with an error code. In safe mode, I was able to uninstall the drivers and almost everything is back to normal.
By the way, I saw the problem that I can not restore the system to the last known good point, and now the computer is already running, I see that it lacks the tab "System Protection". After entering the system is, but when I click on it so it looks like the attached photo.
I've tried all sorts of instructions from the search for missing values in the registry by the sfc / scannow, and try to Refresh your PC, which ends with a message
"A problem occurred when refreshing the computer".
Eset computer scanned, Malwarebytes, Aw Cleaner, CCleaner, Wise Registry Cleaner, Dr.Web anti-virus;
I would prefer to restore the system to work for the safety of my files 2
As for the context menu that does not work I print option, returning the error:
"With this file is not associated program to perform this action. Install the program or, if it is already installed, create an association, using the Default Programs applet in the Control Panel." I tried to do this and assign the printing ControlCenter4 but something does not go to me.
I hope that you will help me, because you're already a lifeline.
Refreshing the system shows an error.
And to all a Happy New Year!
Start - Run - regedit - Go To:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\SystemRestore
Find the value DisableSR and if it is set to 1 set it to 0 or delete it.
    Win 8.1.1 Pro x64
    Lenovo E525
    AMD A4-3300M @ 2,0GHz
    6GB DDR3 1333MHz
    AMD Radeon HD 6480G 512MB shared
    Creative Sound Blaster X-Fi Surround 5.1
    1366x768
    WD 465GB
    Fusion Tweaker
    Logitech K360
    Logitech M705
    50/50 MBps
    Yandex
    No AV & No Firewall
    Headphones: Sennheiser RS170
DisableSR is 0.
I tried different solutions to the changes in the registry, refresh, with an attempt to repair any missing or damaged files but unfortunately it did not help.
