system restore not restoring
calmat
error check.JPGsystem restore.JPGhi everyone
tried to do system restore and got this message (see attached) I then did an error check on C drive and I got this message.(see attached) Can anyone please help.
regards ron moore
topgundcp
First, you might try to run a couple of commands from the elevated command prompt to see if you can fix it:
  1. dism /online /cleanup-image /restorehealth
  2. sfc /scannow
Then try to restore again. If you don't succeed, then again run chkdsk offline from the command prompt:
type: chkdsk /r /f c:
You will need to reboot for chkdsk to run. It might take a while.
FYI, never rely on system restore, often they become corrupted. I always turn off system restore.
Reasons:
  1. They are not reliable
  2. They take up disk space
  3. they slow down your system
  4. The restore points are stored in C:\Windows\System Volume Information so it does no help if your C: drive becomes corrupted.
Your best bet is to have a good backup image stored in an external HD so in case your PC get infected, becomes unbootable, etc... then it would take no time to restore and back online.
Here's one good free backup software: Macrium Reflect Free
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
proudtobegreek
still learning
Exactly my way,of staying on the safe side.Macrium Reflect,is the most reliable,software based solution,to get back "online"in less than ten minutes.
One could always,make good use of,them just laying around-no use-small sized-older HDDs,and clone your bootup partition and be up and going in a matter of hook it up and ready to get going,at next restart.
    W8 Pro 64bit
    Home...made ®
    Intel i7 2600k
    GA-Z68X-UD3P-B3
    Corsair Vengeance 4x4Gb 1600 Mhz
    ASUS GTX 680 DirectCU II SLI
    onboard
    LG Flatron W2240S PN
    SanDisk Ultra Plus SATA 3 128GB X2
    Western Digital Caviar Blue 2x1TB + WD Caviar Black 1TB
    Corsair RM 850 X
    Chieftec Dragon
    Thermalright Macho HR-02
    Ivation mechanical backlit
    MS Optical 6000
    24 Mbps
    Chrome
    ESET NOD32 8.0.312.0
calmat
hi everyone
thanks for all your help, I have done what you recommended and now system restore worked.
I have down loaded macrium reflect, but I don't really know how to use it, can you please help.
How do I turn off system restore.
regards calmat
topgundcp
Good to hear it's working .
First hold down Win key + X . Click on System then follow the steps from the screen shot.
Here's the link for: Macrium User Manual
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
